Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Can I use 914-6 5 lug hubs, wheels rotors, etc?
What are the differences in the 914-6 Caliper and the M- Calipers? Can I leave the engine lid out and build a tray for the carbs? What about Scoops mounted in the rear window? Can I leave out body plugs to feed air to the oil coolers? Can holes be cut behind the Fog light mounts to feed brake ducts or oil coolers? Do I have to use the Ginther style windscreen? Can I use multiple tubing sizes in the cage as long as I follow the GCR for the main hoops and side bars? Can I go to full Glass fenders and Quarters? How do you guys do the doors? Can you still open them or weld them shut, etc? Does air have to be fed through the dryer duct for the engine cooling or can I pull air from the open cockpit area? Can I put a fairing over the passenger side? |
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,527 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
Check the rule book for the group / groups you plan to run with.
What is OK for SCCA and PCA might not be legal in HSR or POC. |
Lo-Fi Version | Time is now: 1st July 2024 - 04:10 AM |
