b.stirbu |
1974 daily driver ![]() Group: Members Posts: 27 Joined: 14-June 15 From: Netherlands Member No.: 18,848 Region Association: Europe ![]() |
Dear 914ers,
I'm quite in a pickle with my 914 1.7. The engine sometimes starts sometimes not (usually after it started, ran 5-10 seconds and then stopped and I couldn't manage to start it again). Messing arround in the engine compartment I accidentally unplugged the cyl 4 fuel injector and surprise the engine started and idled low. Tried again one, two, three times and he started succesfully, but as soon as I plug back the cyl 4 injector cable does not want to start again... What's wrong here? (the injector not, because I've swapped 3 with 4 and I still had the same problem). According to the attached current flow cyl 4 injector is in series with the cold start valve and the thermoswitch for the cold start valve.. Am I looking at the right diagram? I also don't know where current track 102 comes from. Also very interesting is that I removed the injectors 3 and 4 and placed them in two cups to see if they work, and I could start the engine in two cylinders (although the cyl 4 injector plug was connected) Cheers, Bogdan Attached thumbnail(s) ![]() |
b.stirbu |
the ground are OK, and I'think the injectors are all working properly..I've tested them outside the intake in some cups. They all sprayed an equal quantity of gas Either they are all faulty or all good..
Now the interesting part comes...The intake for the cilinders that are not operating are Warm...(warmer than the ones that operating) the Exaust of the cilinders that do not operate is cold..it makes me think that either the valves are not adjusted properly for this two cilinders... What makes an intake pipe warm? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:32 AM |
