Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Can I use 914-6 5 lug hubs, wheels rotors, etc?
What are the differences in the 914-6 Caliper and the M- Calipers? Can I leave the engine lid out and build a tray for the carbs? What about Scoops mounted in the rear window? Can I leave out body plugs to feed air to the oil coolers? Can holes be cut behind the Fog light mounts to feed brake ducts or oil coolers? Do I have to use the Ginther style windscreen? Can I use multiple tubing sizes in the cage as long as I follow the GCR for the main hoops and side bars? Can I go to full Glass fenders and Quarters? How do you guys do the doors? Can you still open them or weld them shut, etc? Does air have to be fed through the dryer duct for the engine cooling or can I pull air from the open cockpit area? Can I put a fairing over the passenger side? |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
QUOTE(Racer Chris @ Sep 16 2004, 06:09 AM) Even the dryer tube through the chassis is illegal in a strict interpretation of the firewall rules, and I might go after that someday too. I've seen several SCCA 914's run the stove pipe through the cockpit for engine cooling. I guess since they have not been winning the Runoffs lately this has not been challenged. At the Rennsport Reunion this year at Daytona, I saw the Cogbill PAP 356 that was a past Runoff champ. It was on a trailer and appeared to be in a little rough condition, perhaps not being used. I was surprised to see it had the stovepipe treatment. I didn't know the 356 crowd also did this. |
Lo-Fi Version | Time is now: 1st July 2024 - 04:12 AM |
