Clicking noise at diff shaft |
john77 |
Sep 1 2015, 07:39 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I pulled both my axles to replace the diff shaft seals on my transmission a couple of weeks ago and have noticed my diff is now making a loud clicking noise if I rock the car back and forth. Is this normal? I'm not sure if I'm just being paranoid and it was there before I did the work.
There is play in the shaft, with the back wheels off the ground I can rotate the wheel a little either way before the diff engages. The video below is the car parked and me just rocking it back and forth. I torqued the trans flange bolt to 19ft/lbs. https://youtu.be/_Fd0a1WgzHM |
euro911 |
Sep 1 2015, 09:10 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Reusing the output hub flange bolts is fine, but it's recommended to use new bolts for the CV joints.
Does the clicking only emanate from one side of the trans? I wonder if you have a bad CV joint on your hands? |
Lo-Fi Version | Time is now: 18th September 2024 - 07:08 PM |
