b.stirbu |
1974 daily driver ![]() Group: Members Posts: 27 Joined: 14-June 15 From: Netherlands Member No.: 18,848 Region Association: Europe ![]() |
Dear 914ers,
I'm quite in a pickle with my 914 1.7. The engine sometimes starts sometimes not (usually after it started, ran 5-10 seconds and then stopped and I couldn't manage to start it again). Messing arround in the engine compartment I accidentally unplugged the cyl 4 fuel injector and surprise the engine started and idled low. Tried again one, two, three times and he started succesfully, but as soon as I plug back the cyl 4 injector cable does not want to start again... What's wrong here? (the injector not, because I've swapped 3 with 4 and I still had the same problem). According to the attached current flow cyl 4 injector is in series with the cold start valve and the thermoswitch for the cold start valve.. Am I looking at the right diagram? I also don't know where current track 102 comes from. Also very interesting is that I removed the injectors 3 and 4 and placed them in two cups to see if they work, and I could start the engine in two cylinders (although the cyl 4 injector plug was connected) Cheers, Bogdan Attached thumbnail(s) ![]() |
b.stirbu |
Guys, first of all, I would like to thank you for you help and ideas.
With all the shame I have to share my story, maybe it can be a lesson learned for other 914ers (and not only). When I changed the piston rings I also removed the rocker arms (and rods), in order to inspect them. When I fit the rocker arms back, I've must have done something wrong with the torque settings (or the wrench is not properly calibrated), because: - On cilinder 1 - one nut jumped off and one was loose - On cilinder 3 - both nuts jumped off... Luckily the rocker arms are held in place by that wire underneath them... After I've tight them back (I might have tight them a bit too hard) and readjust the valves, the car started from the first turn of the key.. I could not sleep last night thinking that I'm so close of driving it... It idles ok, it might need a bit of tunning, and I think I have to tune the throttle, because after acceleration I have to push is back a bit to decrease the RPMs.. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:25 AM |
