Clicking noise at diff shaft |
john77 |
Sep 1 2015, 07:39 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I pulled both my axles to replace the diff shaft seals on my transmission a couple of weeks ago and have noticed my diff is now making a loud clicking noise if I rock the car back and forth. Is this normal? I'm not sure if I'm just being paranoid and it was there before I did the work.
There is play in the shaft, with the back wheels off the ground I can rotate the wheel a little either way before the diff engages. The video below is the car parked and me just rocking it back and forth. I torqued the trans flange bolt to 19ft/lbs. https://youtu.be/_Fd0a1WgzHM |
TheCabinetmaker |
Sep 2 2015, 05:59 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The cv is welded to the axle? I'd toss that axle and get a used one. The other CV that has no circlip is a disaster waiting to happen. The cvs are not reversible. You should return all that hacked up crap to original. I don't know about the van cv's, but the type I vw's will fit but lacks the machined lip that the gasket sits on.
Lo-Fi Version | Time is now: 18th September 2024 - 06:57 PM |
