MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
Hi all...I have a 2 part question that hopefully someone can help me with.
1. It seems I can't tighten the front wheel bearings quite enough to get to the "tightness" that I want. The adjuster doesn't want to turn in any more and I don't want to force it. Is this an indication of not enough grease in the bearings? 2. I have the front wheels off the car. When I spin the hub and rotor back and forth I get a slight knock when the rotor starts and stops. I can really feel it in the strut also. Is this normal? Am I explaining this properly? It is not wheel bearing slop. Thanks, Mike |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
I don't know, but what you are describing isn't right. The proper parts should go together fine and be adjustable.
Lo-Fi Version | Time is now: 25th June 2024 - 06:47 PM |
