tach |
Member ![]() ![]() Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest ![]() |
I ordered new VW type 1 lobro cv joints for my 914 but the 2 roll pin holes need to be bored out to 10mm X 20mm deep. I was wondering if I can just bore out the hole on my drill press with a 10mm drill bit or do I need to have the hole machine larger with a end mill by a machine shop?
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
I ordered new VW cv joints for my 914 but the 2 roll pin holes need to be bored out to 10mm X 20mm deep. I was wondering if I can just bore out the hole on my drill press with a 10mm drill bit or do I need to have the hole machine larger with a end mill by a machine shop? A roll pin should be a press fit. Don't understand your question. Is there no hole in the CV for a roll pin? |
Lo-Fi Version | Time is now: 25th June 2024 - 08:14 PM |
