mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,393 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
Just missed out on a set of sway bars in the Classified but have a question for those who know-
I'm looking for front and rear sway bars for my car which is running a heavier than stock equipment EG33 and was wondering what has worked for others? I know Tarrett and other companies make the full-on race bars but I don't think I'll need something that fancy. Anyone have experience with Addco or any other aftermarket bars? Any opinions on what would work, possibly someone with a V8 conversion could chime in as to what their builds are runnning? That would be in the weight range- I may run an autocross and a track once in awhile but mainly spirited driving on twisty roads which is everyones favorite! What works on your car? |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I wont say "all", but "most" 914 racers that I know of do not use a rear sway bar.
The 914s on the track are about the "flatest" cornering cars of all the vintage cars on the track even without rear bars. I believe the mid engine contributes a lot to that. I think the biggest argument against rear bars is that it will make the car more likely to lift a rear wheel. So unless you have a LSD, that is a highly undesirable trait. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,715 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I wont say "all", but "most" 914 racers that I know of do not use a rear sway bar. The 914s on the track are about the "flatest" cornering cars of all the vintage cars on the track even without rear bars. I believe the mid engine contributes a lot to that. I think the biggest argument against rear bars is that it will make the car more likely to lift a rear wheel. So unless you have a LSD, that is a highly undesirable trait. That only applies to race cars and dedicated AX cars. For a street car, a rear sway bar is indeed desirable. In fact, i have one on my car and only disconnect it for AX. (IMG:style_emoticons/default/shades.gif) |
stugray |
That only applies to race cars and dedicated AX cars. For a street car, a rear sway bar is indeed desirable. In fact, i have one on my car and only disconnect it for AX. (IMG:style_emoticons/default/shades.gif) I would like to understand why. I could imagine that one difference between track & street is that on the street you would have a greater chance of more serious bumps like speed bumps, potholes or gutters. But in those cases I would think that a less stiff suspension might be the better choice. (IMG:style_emoticons/default/confused24.gif) I guess Ive never had a rear bar and my current springs are 275s so I dont know what "normal" feels like. |
SirAndy |
I would like to understand why. There are only two scenarios where you DON'T want a rear sway bar and both of those only apply if you don't have a limited slip in your transmission. - In really tight low speed corners where you need to accelerate out of the corner with as much throttle as possible. - Under hard (trail) braking when entering a tight corner. This really only presents a problem at the race track or at an AX. The reason being that in those scenarios, the rear bar will tend to lift the inner wheel and without a limited slip in your transmission, you will get wheel spin under acceleration and loss of traction under braking. Under any other driving condition a rear bar will actually help balancing the car and improve corner stability. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 3rd July 2024 - 05:35 AM |
