carphappy |
Newbie ![]() Group: Members Posts: 13 Joined: 6-September 15 From: hudson valley, ny Member No.: 19,132 Region Association: North East States ![]() |
hi everyone. several years ago i built myself a jdm ej20k subaru powered 914. unfortunately i did not document my progress. because it already had an aftermarket body kit installed i had no ethical reasons not to install a different motor. i am using a diy megasquirt ecu with the stock cam and crank sensors to control the motor. to say that i learned a thing or two along the way would be an understatement. thanks to everyone who has done a subaru conversion before me. your posts have inspired me and helped in numerous decision making situations. here are a couple of pics.
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp?
carphappy |
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp? i am using the stock temp gauge as an oil temp gauge. i installed an electric sending unit in the oil pan and hooked it up to the existing wire. on hot days it moves beyond vertical but it has never reached the red zone. i am thinking that it is relatively accurate. i made the center console, it holds the oil pressure, water temp, boost, and afr gauges. |
TheBabyBadger |
Newbie ![]() Group: Members Posts: 8 Joined: 25-August 15 From: Fairfield, CA Member No.: 19,103 Region Association: Northern California ![]() |
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp? i am using the stock temp gauge as an oil temp gauge. i installed an electric sending unit in the oil pan and hooked it up to the existing wire. on hot days it moves beyond vertical but it has never reached the red zone. i am thinking that it is relatively accurate. i made the center console, it holds the oil pressure, water temp, boost, and afr gauges. Awesome build! Love the set up. Venting through the floor? Wheel wells? Would love to see more pics. I run the same kit on my car. |
carphappy |
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp? i am using the stock temp gauge as an oil temp gauge. i installed an electric sending unit in the oil pan and hooked it up to the existing wire. on hot days it moves beyond vertical but it has never reached the red zone. i am thinking that it is relatively accurate. i made the center console, it holds the oil pressure, water temp, boost, and afr gauges. Awesome build! Love the set up. Venting through the floor? Wheel wells? Would love to see more pics. I run the same kit on my car. when deciding where the warm air would go from the radiator i looked at several options, some people have vented out the hood (did not like how that looked), most people cut holes in the wheel wells and add a wire mesh (i think that a fair amount of road debris would end up in the front boot), and some cut a big rectangle in the floor. i ended up cutting a small rectangle and creating an additional vent slat. the rectangle makes it easy to plumb coolant to and from the radiator, and the additional vent hopefully helps with air flow. it doesn't look as bad as it does in the pictures and water temps only occasionally rise high enough to turn the electric fans on. Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 10:20 PM |
