earossi |
Member ![]() ![]() Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest ![]() |
In attempting to install the top on my car, I encountered resistance from the new front seal that goes across the windshield. The seal, being new, has not taken a set, so it took a lot of force attempting to "pull" the top forward into the seal. So much force that I managed to break one of the pot metal latches on one side, and the stepped pivot screw on the other latch sheared off at the threads.
The top was latched in place when I picked up the car, but I am obviously doing something wrong. So, I have several questions. First, is where to source new latches and the stepped pivot screw that I managed to break. I assume that I can source them used by placing an ad in the WTB parts section of classified; but, it would be nice to install new parts, if they can be sourced. Second, any suggestions on why I ran into the latching issue? When I placed the top on the car, I indexed the front lip into the windshield seal, and then attempted to pull it into place with the latches, until the latches failed. Obviously, something is not correct. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Your old seal had taken a set over the years and lost it's elasticity.
The new seal is probably "puffier" as it is new. On the latches there are adjustment studs for such an occurrence. You would loosen the nuts and let the latch catch slide a bit. Boiled down .... Old seal = thin and New seal = thicker. You should be able to push the top into place in the seal. You could try some lube on the seal (soapy water). That's my take. |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Your old seal had taken a set over the years and lost it's elasticity. The new seal is probably "puffier" as it is new. On the latches there are adjustment studs for such an occurrence. You would loosen the nuts and let the latch catch slide a bit. Boiled down .... Old seal = thin and New seal = thicker. You should be able to push the top into place in the seal. You could try some lube on the seal (soapy water). That's my take. Puffier? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:10 AM |
