Grinding in 1st and reverse |
BfloRandy |
Sep 10 2015, 10:02 AM
Dimwit Extraordinaire Group: Members Posts: 66 Joined: 20-September 14 From: Buffalo, NY Member No.: 17,927 Region Association: North East States |
Hello!
Noticed another fun new issue the other day... After the car gets warmed up, I get a little bit of grinding going into both first and reverse. Doesn't happen when cold. Doesn't do it in 2-5. It's not horrible (yet) but it certainly is annoying. I've gathered from searching other posts that I may need to adjust my linkage. As it happens, I plan on installing the Weltmeister short kit this afternoon. Think I'm on the right track? If so, any tips on adjustments would be appreciated. Thanks! -Randy |
Bruce Hinds |
Sep 10 2015, 10:20 AM
V-8 madness Group: Members Posts: 734 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Sounds like a clutch adjustment to me. As the cable gets older it can stretch slightly.
If you can't get a good adjustment, check the tube the cable runs through where it attaches to the firewall. That can work it's way loose so you just can't get a good adjustment. Other places through the tunnel where it spot welded tend to work loose too. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:57 AM |
