BfloRandy |
Dimwit Extraordinaire ![]() ![]() Group: Members Posts: 66 Joined: 20-September 14 From: Buffalo, NY Member No.: 17,927 Region Association: North East States ![]() |
Hello!
Noticed another fun new issue the other day... After the car gets warmed up, I get a little bit of grinding going into both first and reverse. Doesn't happen when cold. Doesn't do it in 2-5. It's not horrible (yet) but it certainly is annoying. I've gathered from searching other posts that I may need to adjust my linkage. As it happens, I plan on installing the Weltmeister short kit this afternoon. Think I'm on the right track? If so, any tips on adjustments would be appreciated. Thanks! -Randy |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Start with tightening the clutch adjuster nuts a couple turns.
Also, consider whether the trans fluid has been changed recently, or ever. The good Dr. Evil, our resident transmission expert suggests using 75w-90 "dino" oil - not Mobil 1 or other synthetic. Some people like Swepco, but I use the cheap stuff from WalMart, and it works great for me. The short shift kit has nothing to do with how well the car shifts. Only the length of the throw that you, the driver feels. Some think it can actually exacerbate other problems like a mis-adjusted cable, worn bushings, etc. |
BfloRandy |
(IMG:style_emoticons/default/agree.gif) Start with tightening the clutch adjuster nuts a couple turns. Also, consider whether the trans fluid has been changed recently, or ever. The good Dr. Evil, our resident transmission expert suggests using 75w-90 "dino" oil - not Mobil 1 or other synthetic. Some people like Swepco, but I use the cheap stuff from WalMart, and it works great for me. The short shift kit has nothing to do with how well the car shifts. Only the length of the throw that you, the driver feels. Some think it can actually exacerbate other problems like a mis-adjusted cable, worn bushings, etc. I've been planning on replacing the shifter since last fall, when the original lever snapped off at the ball. Had it welded, all is good, but had already ordered the short shift kit in case the thing wasn't weldable. Just figured that while I'm in there replacing it, I might want to adjust the linkage. 1st is a little close to my knee... I have not changed the tranny fluid. Perhaps it's low? Where the heck do you check it? (IMG:style_emoticons/default/confused24.gif) Never saw a dipstick for it, feeling kinda dumb for not investigating! IIRC, the last time I had the car on a lift, the cable had a boatload of things (spacers, nuts, etc) on the free end of it to get it to fit. Also, the clutch doesn't engage until the pedal is almost on the floor. (That's not a new thing, been that way since I got her.) I'm thinking new cable, as well as bushings. I'll look in the tunnel before I order them, to check the tube as well. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:14 AM |
