> Solo Brake Bleeding
EdwardBlume
post Sep 10 2015, 10:44 AM
I have a spongy brake pedal that firms up upon pumping. No visible leaks, I think the brakes just need bleeding.
Any good how to descriptions, especially how I can do it by myself? What equipment is needed to fill fluid?
Thanks,
Rob
andrewb
post Sep 10 2015, 12:47 PM
I use a jack handle or a piece of wood and a piece of clear hose. No expensive kit, no assistant. (Probably no friends either (IMG:style_emoticons/default/sad.gif) )
1. Get a piece of wood (say 2" x 2") about 18" long (or a jack handle) and position the drivers seat so that the distance from the brake pedal to the front of the seat base is slightly less than the length of the piece of wood.
2. Now slide the seat forward another couple of clicks so that when you wedge the wood between the seat base and the pedal it applies pressure to the pedal. Don't put the wood in place just yet.
3. Starting with the caliper furthest from the master cylinder, assuming you're doing all 4, undo the bleed nipple and make sure it turns freely - then nip it up gently. Put a ring spanner on the nipple and then the clear hose onto the nipple with the other end into a container.
4. Put one end of the piece of wood on the brake pedal and push it until the other end is wedged against the front of the seat.
5. Open the bleed nipple a fraction - it will spit some air out and maybe a bit of fluid. Quickly nip the nipple back up.
6. The piece of wood will no longer be tightly wedged because you've released the pressure that was holding the pedal up. Remove the wood, allowing the pedal to come back up, and then wedge the wood back in place as before. Repeat stage 5.
Each time more fluid and less air bubbles will appear in the clear hose. Once you have clear fluid and no bubbles give it 2 or 3 more cycles to be sure and then you're done. Tighten the nipple properly and then do the other 3 in order of decreasing distance from the master cylinder.
Don't forget to keep topping up the reservoir.
I've been doing it this way for over 30 years starting with a '67 Beetle and I'm still doing it on newish cars with ABS. Works every time.
Andrew
RobW   Solo Brake Bleeding   Sep 10 2015, 10:44 AM
Martin Baker   Here is the method I use, to bleed brakes alone, o...   Sep 10 2015, 12:25 PM
aircooledtechguy   A great little tool that is normally available at ...   Sep 10 2015, 12:29 PM
Bartlett 914   When I bleed brakes, I place the plastic tube movi...   Sep 10 2015, 12:42 PM
andrewb   I use a jack handle or a piece of wood and a piece...   Sep 10 2015, 12:47 PM
Jeff Bowlsby   Speedbleeders, a length of clear tubing and a cont...   Sep 10 2015, 12:59 PM
Elliot Cannon   :agree:   Sep 10 2015, 01:57 PM
dlee6204   Nothing special. I run clear tubing from the cali...   Sep 10 2015, 02:11 PM
Kansas 914   Nothing special. I run clear tubing from the cal...   Sep 10 2015, 05:02 PM
steuspeed   Nothing special. I run clear tubing from the ca...   Sep 29 2015, 07:40 PM
kupcar   I've used a Mighty Vac pressure bleeder for ye...   Sep 10 2015, 03:53 PM
Jeffs9146   I have used this for 20+ years!   Sep 10 2015, 03:59 PM
Cairo94507   Hey Rob - If all you need is a body for assistance...   Sep 10 2015, 04:17 PM
RobW   Hey Rob - If all you need is a body for assistanc...   Sep 10 2015, 04:43 PM
RobW   Thanks for all the input guys! I'll see wh...   Sep 10 2015, 04:44 PM
RobW   How much brake fluid should I buy then? and what t...   Sep 10 2015, 05:19 PM
r_towle   How much brake fluid should I buy then? and what ...   Sep 10 2015, 06:55 PM
kconway   Rob...FYI, The fluid in that system is "newis...   Sep 11 2015, 11:49 AM
RobW   Rob...FYI, The fluid in that system is "newi...   Sep 12 2015, 05:18 AM
kconway   [quote name='kconway' post='2235967' date='Sep 11...   Sep 12 2015, 08:30 AM
smj   I've used the Motive pressure bleeders for yea...   Sep 10 2015, 09:44 PM
yeahmag   Love my Motiv...   Sep 10 2015, 10:10 PM
infraredcalvin   Do not route old fluid back into resovoir, it defe...   Sep 10 2015, 10:13 PM
mgp4591   If you don't find any air, you may have a bind...   Sep 10 2015, 11:29 PM
DBCooper   There's a CSOB old farmer's way of pressur...   Sep 12 2015, 08:27 AM
RobW   So I'm ready to roll with the bleed. Another...   Sep 21 2015, 04:15 PM
914Mike   So I'm ready to roll with the bleed. Anothe...   Sep 21 2015, 06:17 PM
C-Ya MK   A couple of months ago I replaced my mc and I bled...   Sep 21 2015, 08:37 PM
relentless   I'm just in the process of bleeding my brakes ...   Sep 22 2015, 09:50 AM
RobW   I'm just in the process of bleeding my brakes...   Sep 22 2015, 01:31 PM
Markl   There's a CSOB old farmer's way of pressu...   Sep 28 2015, 11:17 PM
relentless   The pictures I promised are in my new brake thread...   Sep 29 2015, 10:51 AM
colingreene   i would not use food dye. It often is water based.   Sep 29 2015, 06:15 PM
jimkelly   I gave speed bleeders a try and like them :D ht...   Oct 11 2015, 07:51 AM
RobW   I gave speed bleeders a try and like them :D h...   Oct 11 2015, 07:54 AM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 01:04 AM
