> Solo Brake Bleeding
EdwardBlume
post Sep 10 2015, 10:44 AM
I have a spongy brake pedal that firms up upon pumping. No visible leaks, I think the brakes just need bleeding.
Any good how to descriptions, especially how I can do it by myself? What equipment is needed to fill fluid?
Thanks,
Rob
EdwardBlume
post Sep 10 2015, 05:19 PM
How much brake fluid should I buy then? and what type of brake fluid is ideal? does it matter?
r_towle
post Sep 10 2015, 06:55 PM
Custom Member
QUOTE(RobW @ Sep 10 2015, 07:19 PM) *
If you have never changed your brake fluid, it may be in your best interest to do it.
Couple of quarts will do it.
DOT4
Add red food coloring dye.
Pump till it comes out red on all four corners.
Start with the passenger rear, then drivers rear, then passenger front, then drivers front.
Next year use clear fluid, or use blue food coloring dye.
Speed bleeders and a hose into a bottle will save you relationship issues.
A pressure bleeder like Jeff posted will make the whole project a dream.
Rich
RobW   Solo Brake Bleeding   Sep 10 2015, 10:44 AM
Martin Baker   Here is the method I use, to bleed brakes alone, o...   Sep 10 2015, 12:25 PM
aircooledtechguy   A great little tool that is normally available at ...   Sep 10 2015, 12:29 PM
Bartlett 914   When I bleed brakes, I place the plastic tube movi...   Sep 10 2015, 12:42 PM
andrewb   I use a jack handle or a piece of wood and a piece...   Sep 10 2015, 12:47 PM
Jeff Bowlsby   Speedbleeders, a length of clear tubing and a cont...   Sep 10 2015, 12:59 PM
Elliot Cannon   :agree:   Sep 10 2015, 01:57 PM
dlee6204   Nothing special. I run clear tubing from the cali...   Sep 10 2015, 02:11 PM
Kansas 914   Nothing special. I run clear tubing from the cal...   Sep 10 2015, 05:02 PM
steuspeed   Nothing special. I run clear tubing from the ca...   Sep 29 2015, 07:40 PM
kupcar   I've used a Mighty Vac pressure bleeder for ye...   Sep 10 2015, 03:53 PM
Jeffs9146   I have used this for 20+ years!   Sep 10 2015, 03:59 PM
Cairo94507   Hey Rob - If all you need is a body for assistance...   Sep 10 2015, 04:17 PM
RobW   Hey Rob - If all you need is a body for assistanc...   Sep 10 2015, 04:43 PM
RobW   Thanks for all the input guys! I'll see wh...   Sep 10 2015, 04:44 PM
RobW   How much brake fluid should I buy then? and what t...   Sep 10 2015, 05:19 PM
r_towle   How much brake fluid should I buy then? and what ...   Sep 10 2015, 06:55 PM
kconway   Rob...FYI, The fluid in that system is "newis...   Sep 11 2015, 11:49 AM
RobW   Rob...FYI, The fluid in that system is "newi...   Sep 12 2015, 05:18 AM
kconway   [quote name='kconway' post='2235967' date='Sep 11...   Sep 12 2015, 08:30 AM
smj   I've used the Motive pressure bleeders for yea...   Sep 10 2015, 09:44 PM
yeahmag   Love my Motiv...   Sep 10 2015, 10:10 PM
infraredcalvin   Do not route old fluid back into resovoir, it defe...   Sep 10 2015, 10:13 PM
mgp4591   If you don't find any air, you may have a bind...   Sep 10 2015, 11:29 PM
DBCooper   There's a CSOB old farmer's way of pressur...   Sep 12 2015, 08:27 AM
RobW   So I'm ready to roll with the bleed. Another...   Sep 21 2015, 04:15 PM
914Mike   So I'm ready to roll with the bleed. Anothe...   Sep 21 2015, 06:17 PM
C-Ya MK   A couple of months ago I replaced my mc and I bled...   Sep 21 2015, 08:37 PM
relentless   I'm just in the process of bleeding my brakes ...   Sep 22 2015, 09:50 AM
RobW   I'm just in the process of bleeding my brakes...   Sep 22 2015, 01:31 PM
Markl   There's a CSOB old farmer's way of pressu...   Sep 28 2015, 11:17 PM
relentless   The pictures I promised are in my new brake thread...   Sep 29 2015, 10:51 AM
colingreene   i would not use food dye. It often is water based.   Sep 29 2015, 06:15 PM
jimkelly   I gave speed bleeders a try and like them :D ht...   Oct 11 2015, 07:51 AM
RobW   I gave speed bleeders a try and like them :D h...   Oct 11 2015, 07:54 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 12:22 AM
