Solo Brake Bleeding |
EdwardBlume |
Sep 10 2015, 10:44 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I have a spongy brake pedal that firms up upon pumping. No visible leaks, I think the brakes just need bleeding.
Any good how to descriptions, especially how I can do it by myself? What equipment is needed to fill fluid? Thanks, Rob |
mgp4591 |
Sep 10 2015, 11:29 PM
914 Guru Group: Members Posts: 5,509 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
If you don't find any air, you may have a binding pad or sticking caliper piston- it feels the same as air and reacts about the same with less that ideal braking, maybe even pulling to the opposite side as the offending unit. Good luck- reading through the other comments you should be able to fix your problem.
Lo-Fi Version | Time is now: 27th December 2024 - 12:55 AM |
