2200rpm idle & stumbles around 3200 when driving, making progress, idle down to 1100, still stumbles above 3k |
RazorbackFan78 |
Sep 8 2015, 06:30 PM
3 different layers of paint helps protect if from rust Group: Members Posts: 136 Joined: 29-March 13 From: Bentonville, AR Member No.: 15,709 Region Association: South East States |
Hey guys - I'm trying to track down the cause of my high idle.
I've checked the TPS and I get 20 clicks pre-ignition I've pulled the AAR, soaked it in PBlaster, froze it, put 12v through it, confirming it opens and closes correctly. It also tested around 17ohms I cleaned grounds at headlights, battery neg, driverside engine bay, and visually confirmed trans strap is brand spankin' new (thanks Curt) Now i'm checking hoses for vac leaks and only one seems to drop the idle (drops it to a steady 1100rpm). It's the hose from the airbox elbow that Y's into the AAR and dizzy. See picture. Is this sounding like my dizzy could use a good cleaning? I have other items on my troubleshooting list like MPS, fuel filter and decel valve but wanted to check in with you guys after discovering the vac issue. Thanks for your input. I'm still fairly new to this type of engine....so I'm learning as I go (IMG:style_emoticons/default/biggrin.gif) BACKSTORY: for those of you who like a novel....car had points and idle would bounce between 100-900rpm more often than not. Anytime I'd reach 3200rpm while driving it would studder and loose power, in all gears, and it would also occasionally do it under a heavy foot at lower rpms. I replaced points with Pertronix 1847V and now the cold idle sits on 1100 like a rock for the first minute or so, then over the next minute it climbs to 2200 and holds steady. It still studders around 3200 when driving and occasionally does it at lower rpms when I'm really on the pedal. Attached image(s) |
RazorbackFan78 |
Sep 11 2015, 04:41 PM
Glad to read that the hiss is normal with the air cleaner off. One less thing for me to worry about. Sometimes I really do feel like a doofus compared to you guys when I'm working on this car (IMG:style_emoticons/default/blink.gif)
So anyway, before I go pulling off the TB & Plenum to check for leaks, I thought I'd quickly try disconnecting the TPS to see if my 3000rpm stumble went away (I'd read a few other posts where people recommended disconnecting it to determine if it was the cause of the high rpm/WOT stumbling. I disconnected it and took it for a spin. Engine seemed to run strong all the way to 4k but then started a small studder...not as bad as when it did it around 3k. But UGHHH the idle climbs to 2200 now and stays there unless I drag it back down with the clutch. Then it sits at 1100 for 20-30 seconds and climbs back up to 2200. Anyway, I'll reconnect TPS and see if it goes back to idling at 1100 and studdering at 3k. The company I work for is Jewish-owned and operated which means I'm off for the next four days. Woohoo!!! Hopefully I can the gremlins worked out by then. I'm trying to stick to the one-change-at-a-time mantra!. |
Lo-Fi Version | Time is now: 2nd July 2024 - 03:27 AM |
