2200rpm idle & stumbles around 3200 when driving, making progress, idle down to 1100, still stumbles above 3k |
RazorbackFan78 |
Sep 8 2015, 06:30 PM
3 different layers of paint helps protect if from rust Group: Members Posts: 136 Joined: 29-March 13 From: Bentonville, AR Member No.: 15,709 Region Association: South East States |
Hey guys - I'm trying to track down the cause of my high idle.
I've checked the TPS and I get 20 clicks pre-ignition I've pulled the AAR, soaked it in PBlaster, froze it, put 12v through it, confirming it opens and closes correctly. It also tested around 17ohms I cleaned grounds at headlights, battery neg, driverside engine bay, and visually confirmed trans strap is brand spankin' new (thanks Curt) Now i'm checking hoses for vac leaks and only one seems to drop the idle (drops it to a steady 1100rpm). It's the hose from the airbox elbow that Y's into the AAR and dizzy. See picture. Is this sounding like my dizzy could use a good cleaning? I have other items on my troubleshooting list like MPS, fuel filter and decel valve but wanted to check in with you guys after discovering the vac issue. Thanks for your input. I'm still fairly new to this type of engine....so I'm learning as I go (IMG:style_emoticons/default/biggrin.gif) BACKSTORY: for those of you who like a novel....car had points and idle would bounce between 100-900rpm more often than not. Anytime I'd reach 3200rpm while driving it would studder and loose power, in all gears, and it would also occasionally do it under a heavy foot at lower rpms. I replaced points with Pertronix 1847V and now the cold idle sits on 1100 like a rock for the first minute or so, then over the next minute it climbs to 2200 and holds steady. It still studders around 3200 when driving and occasionally does it at lower rpms when I'm really on the pedal. Attached image(s) |
TheCabinetmaker |
Sep 11 2015, 05:08 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Matt, I set your idle to about 1050. Plenum was checked good. I replaced your original which was not. You can turn it down if it seems to high for you. I like mine at 1100. Did you retime after installing the pertronics? BTW, keep your old points and condenser in the glove box with a screwdriver and feeler gauge.
The climbing rpms after 30 seconds is caused by the tps. Plug it back in. |
RazorbackFan78 |
Sep 12 2015, 05:45 AM
Matt, I set your idle to about 1050. Plenum was checked good. I replaced your original which was not. You can turn it down if it seems to high for you. I like mine at 1100. Did you retime after installing the pertronics? BTW, keep your old points and condenser in the glove box with a screwdriver and feeler gauge. The climbing rpms after 30 seconds is caused by the tps. Plug it back in. TPS is reconnected. I'll double check the timing once all my neighbors are awake |
Lo-Fi Version | Time is now: 28th September 2024 - 07:14 AM |
