914/6 Throttle Bellcrank Bracket/Rod/Pivot Shaft, Vintage PELICAN PARTS Item $80.00 S O L D !!! |
Martin Baker |
Sep 13 2015, 07:02 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
S O L D !!! Thanks! Removed this from my racecar, switched to Rich Johnsons bracket, as this one would not work with my new GT Rally Muffler/Header setup. Pelican sold this many years ago, discontinued some time ago. It will not include a 914/6 throttle cable, or a correct 914/6 bell crank. I will include one you could convert. it could be 911, or 912. I do not know. From the old PELICAN ad: This linkage kit is a must for 914-6 conversions. It avoids the nasty process of drilling through your 901 transmission intermediate plate to mount the bell crank. The kit contains four pieces: •A special bracket and crank that mounts to the bolts on the rear cover of the 901 •A 914-6 bracket that holds the end of the accelerator cable •A 914-6 accelerator cable that replaces the 4 cylinder one •A 911 throttle rod, that can be used instead of the expensive 914-6 throttle rod because the bell crank is further back on the transmission. Link to the old ad; http://www.pelicanparts.com/914/914-6_cons..._price_list.htm Attached thumbnail(s) |
scrz914 |
Sep 13 2015, 07:26 PM
Member Group: Members Posts: 401 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
Removed this from my racecar, switched to Rich Johnsons bracket, as this one would not work with my new GT Rally Muffler/Header setup. Pelican sold this many years ago, discontinued some time ago. It will not include a 914/6 throttle cable, or a correct 914/6 bell crank. I will include one you could convert. it could be 911, or 912. I do not know. From the old PELICAN ad: This linkage kit is a must for 914-6 conversions. It avoids the nasty process of drilling through your 901 transmission intermediate plate to mount the bell crank. The kit contains four pieces: •A special bracket and crank that mounts to the bolts on the rear cover of the 901 •A 914-6 bracket that holds the end of the accelerator cable •A 914-6 accelerator cable that replaces the 4 cylinder one •A 911 throttle rod, that can be used instead of the expensive 914-6 throttle rod because the bell crank is further back on the transmission. Link to the old ad; http://www.pelicanparts.com/914/914-6_cons..._price_list.htm I'll take this. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:52 PM |
