My latest Megasquirt install, MS2 w/ITBs, wasted spark, relay board and custom harness |
aircooledtechguy |
Sep 15 2015, 11:46 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Megasquirt EFI is an amazingly capable system that is 100% tuneable. It is, however a mis-understood system and many of it's detractors have either not actually used it themselves or have used a cobbled together system of mis-matched parts. After 8 year of working with Megasquirt and doing installs, I have found that buying a complete, well engineered system with a quality harness is key to success. Also having an expert tuner can't hurt either.
Some may know that I work closely with Mario Velotta from The Dub Shop for all my Megasquirt parts and kits as well as tuning help. Here's a very typical install of one of his kits. You don't need the buy the most expensive kits to get a great running car and Mario will not up-sell you things you don't need for your application. This install was on a 914 2.0L that had factory D-jetronic. Normally we would keep it plenum based re-using much of the factory parts, but with the TB badly worn and this clients desire to clean-up the engine bay, so we went with 40mm ITBs with modern 32# injectors. Ignition is a crank triggered (36-1 wheel mounted behind the fan w/ a bracket and hall sensor) using a coil pack and 8mm plug wires. Exhaust sampling is with an Innovate LC2 All sensors are wired through custom made harnesses. These feed into a relay board. This relay board is not a piece that is 100% necessary to use, but I feel it simplifies and cleans-up the install by getting all fuses and relays used into one neat, clean compact footprint. The install took about 2 days. This included careful removal of the old D-jet system and installation of all the components is the new system. We chose to mount this system in the fwd, right end of the rear trunk. Probably the most difficult part of the install was installing the hall sensor bracket with the engine in place. While totally doable, it was a tedious part of the job. Mario came out to assist in the in-car tuning. The result of a 2-2.5 hour drive is smooth as silk driving from idle to red line, under light throttle or heavy. Acceleration is smooth. No bucking, burping or farting Here is a short video of the test-drive and an over view of the install. https://www.youtube.com/watch?v=e9rcczRTG_M...e=youtube_gdata |
GregAmy |
Sep 16 2015, 08:43 AM
Advanced Member Group: Members Posts: 2,418 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
aircooledtechguy |
Sep 16 2015, 10:19 AM
Hey Nate! I was there yesterday for the final install and I must say this system plus the professional installation done convinces me that my current MegaSquirt will be most improved by you......thanks for letting me sit in! I will be doing away with my current cobbled D-jet injectors and going for the TB plus cleaning up the wire nest that the previous owner made. Unfortunately, I had to leave before the start up which at the time they were narrowing down to starting. Thanks Nate and Mario for helping me find a solution to my bad running 914 plus meeting you guys. Steve It was great meeting you too. We fired it only 30 minutes after you left. . . (IMG:style_emoticons/default/dry.gif) Sorry you missed it. Nice. Normally we would keep it plenum based re-using much of the factory parts... So...any interest in pursuing that? It would make a nice upsell and should improve tunability and drivability. - GA It's not hard to keep all the factory plenum, TB, runners and air cleaner assembly. In this case the owner wanted ITBs due to the poor condition of the original TB. If the original hard parts are in good condition, you can save a fair amount of money that way for sure. There's "up-selling" and there's informing someone on the advantages/disadvantages of both and giving the client what he asks for. This was the later. As far as tuneability and drivability goes, when you dial ITBs in, you get both. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:50 PM |
