> Turbo valve cover modification for installation in a 6, Anybody done it?
bdstone914
post Sep 18 2015, 08:42 AM
bdstone914
I have a customer who wants to add billet lower valve covers to a 6 conversion. He had one machine shop botch the first pair. Anybody done this and know how much material needs to be removed to clear the suspension point? I drawing showing the area to machined and the finished thickness would be ideal.
Please pm me if you can help
Mark Henry
post Sep 18 2015, 10:52 AM
that's what I do!
Turbo covers are heavy, you likely could take the fins right off. Mine are also shaved down to the top of the stud bosses, about 1/4" of fin left.
rgalla9146
post Sep 19 2015, 08:32 AM
QUOTE(Mark Henry @ Sep 18 2015, 12:52 PM) *
Mmmmmm..... twin plug !
Is it difficult to remove the #2 plug connector ?
Mark Henry
post Sep 19 2015, 09:56 AM
that's what I do!
QUOTE(rgalla9146 @ Sep 19 2015, 10:32 AM) *
I just tried it (IMG:style_emoticons/default/wink.gif)
It's tight, you have to sneak it out, but I didn't have to force it
QUOTE(porschetub @ Sep 19 2015, 01:23 AM) *
Yea but my point was that you mill the fins off and that's half of the reason gone to buy them.
Dirt cheap (IMG:style_emoticons/default/idea.gif) my pricing came back as up to $230 each new or $200-300 used hardly dirt cheap,but they used to be.
Personally I would rather speed the money on a good set of engine compartment seals and keep my engine clean underneath than spend this kind of money,there are a lot of good aftermarket gaskets out there to sort this issue with the stock covers also.
Fairs fair but your comparison between between a T1 and a 911 isn't really valid,the 911 motor in a 914 needs all the cooling it can get and generates a lot of oil temp.
Well I admit I haven't needed to buy parts for almost 3 years and I know in that time prices have exploded, but you used to see good used SC covers on the bird for $30-40 a pair. The SC cover looks just like the early mag covers but are heavier and made out of aluminum.
As far as the type one comparison, IMHO is a good comparison it's aircooled and in high performance trim they have all kinds of heat issues. It's all about surface area and air flow, do you really think 4 little fins in a hot area is going to make a huge difference? My 2.0 berg engine running 8 quarts of oil and the added surface area of the sump still over heated, till I put 2" standoffs on the decklid increasing airflow. Oil has a real piss poor heat transfer rate.
The only way fins on the cover will make a noticeable difference is if each cover has ten 3" fins. BTW this as been done by a guy on the bird.
To me good engine seals, etc., is super important on all aircooleds so I totally agree with that statement.
Airflow, engine seals, proper tune and/or a cooler will do way more than a couple of little fins.
bdstone914   Turbo valve cover modification for installation in a 6   Sep 18 2015, 08:42 AM
Luke M   Had this done not too long ago. The machine shop s...   Sep 18 2015, 10:01 AM
mepstein   scotty b did mine at his local shop. 5/16". I...   Sep 18 2015, 10:26 AM
Mark Henry   Turbo covers are heavy, you likely could take the ...   Sep 18 2015, 10:52 AM
rgalla9146   Turbo covers are heavy, you likely could take the...   Sep 19 2015, 08:32 AM
Mark Henry   [quote name='Mark Henry' post='2239216' date='Sep...   Sep 19 2015, 09:56 AM
mepstein   heres what scotty did.   Sep 18 2015, 11:08 AM
396   No need to shave the whole valve cover. The exten...   Sep 18 2015, 06:54 PM
gereed75   No need to shave the whole valve cover. The exte...   Sep 18 2015, 07:27 PM
pete000   No need to shave the whole valve cover. The ext...   Sep 19 2015, 12:08 AM
moriarty   No need to shave the whole valve cover. The ext...   Feb 5 2024, 08:10 AM
porschetub   No need to shave the whole valve cover. The exte...   Sep 18 2015, 07:27 PM
Mark Henry   No need to shave the whole valve cover. The exte...   Sep 18 2015, 09:38 PM
bigkensteele   As far as being weaker the Capt'n used to alw...   Sep 18 2015, 09:50 PM
porschetub   No need to shave the whole valve cover. The ext...   Sep 18 2015, 11:23 PM
colingreene   i could do it, its not exactly hard.   Sep 19 2015, 03:37 AM
gms   If you are not hung up on the O.E. look I highly r...   Sep 19 2015, 11:24 AM
Mark Henry   If you are not hung up on the O.E. look I highly ...   Sep 19 2015, 12:40 PM
ClayPerrine   If you are not hung up on the O.E. look I highly...   Aug 6 2019, 08:51 PM
Maltese Falcon   For easier removal of the valve cover near the tra...   Sep 19 2015, 01:10 PM
Downunderman   I took out all the studs and used flange bolts. S...   Sep 19 2015, 02:25 PM
UROpartsman   If anyone has been considering this upgrade, URO j...   Aug 6 2019, 12:41 PM
burton73   What I have on my 6 #41 Bob B   Aug 6 2019, 09:32 PM
914043   very simple, get an electric grinder with a flappe...   Aug 7 2019, 10:09 PM
914Toy   very simple, get an electric grinder with a flapp...   Aug 8 2019, 08:12 PM
raynekat   Fins are NOT on the turbo covers for cooling. They...   Aug 8 2019, 01:38 PM
ClayPerrine   Fins are NOT on the turbo covers for cooling. The...   Aug 8 2019, 04:53 PM
porschetub   Fins are NOT on the turbo covers for cooling. The...   Aug 9 2019, 05:12 PM
t collins   I milled mine down to just above the bosses using ...   Aug 8 2019, 07:37 PM
UROpartsman   Auto Atlanta just added them to their web site, se...   Aug 9 2019, 10:34 AM
Mark Henry   Auto Atlanta just added them to their web site, s...   Aug 9 2019, 03:07 PM
fixer34   Been there, done that 5+ years ago when I replaced...   Aug 9 2019, 08:38 PM
mb911   You should NOT be required to machine the covers t...   Aug 10 2019, 11:23 AM
mepstein   Both sides   Feb 5 2024, 08:42 AM
moriarty   Both sides OK. Thanks for the info, i'll get...   Feb 8 2024, 06:01 AM
fixer34   My pictures are a couple posts earlier, I don...   Feb 5 2024, 12:59 PM
nditiz1   When I swapped to turbo covers, I only had an issu...   Feb 8 2024, 07:00 AM
brant   Every car is slightly different It could also mat...   Feb 8 2024, 08:13 AM
- Lo-Fi Version Time is now: 20th April 2025 - 12:17 AM
