Bulldog9 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region ![]() |
As I round the final corner, I need to wrap up the crankcase breather and fuel tank vent system. The 912E has a fuel filler vent that runs from the tank to a canister up front, then runs a small vacuum line to the rear that plugs into what looks like a charcoal canister. This canister also has a larger inlet and outlet. I am assuming the outlet can go to the breather can, and also lines from breather can to the inside of the air filter on the carbs.
Looking at the left side of the fan housing on the type 4 motor, I see a nipple. I'm 99% sure that this is to go to the inlet side of the vac canister. Based on some of my reading and files,, I've been planning a simple breather can. http://www.hamincgroup.com/type4-test.php I decided to draw out what I am planning, black lines are confirmed, the blue is what I am thinking. Anyone have recommendations or thoughts on this? I've seen breather cans that run from $80 - $300. Thanks Attached thumbnail(s) ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
True, the OEM set up is injected. It's vented into the intake plenum. SO technically it should be "T"ed and ran into the carb intakes. Perhaps adding dual nippes to the top of the cab air cleaner assemblies?
Catch can works nicely too. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:46 AM |
