> Turn signals, won't work
arkitect
post Sep 21 2015, 11:49 PM
I'm just about an idiot when it comes to electrical. Is there a simple cure for my lack of turn signals on my 73? And before you say look at the electrical diagram....forget it. Too small for my old eyes to read much less figure out.
They use to work, but over time don't anymore. Is there a ground up front for them, relay went bad, fuse. What is a common thing that I might be able to fix?
Any help would be welcome.
Dave
Dave_Darling
post Sep 22 2015, 09:27 AM
914 Idiot
QUOTE(arkitect @ Sep 21 2015, 10:49 PM) *
There are larger-format diagrams available. If nothing else, you can have the ones available on-line blown up large and printed. There really is no substitute for reading the diagrams.
--DD
arkitect   Turn signals   Sep 21 2015, 11:49 PM
914Mike   Fuse is first. Check fuses, bulbs, and sockets for...   Sep 22 2015, 12:23 AM
RobW   There's no easy cure. You have to get in there...   Sep 22 2015, 06:58 AM
Dave_Darling   And before you say look at the electrical diagram....   Sep 22 2015, 09:27 AM
Spoke   I know you don't want to look at an electrical...   Sep 22 2015, 11:21 AM
arkitect   The turn indicator lit up for a few seconds but no...   Sep 22 2015, 10:42 PM
arkitect   I thought I might be onto something. Cleaned the g...   Sep 28 2015, 09:34 PM
arkitect   The 3 wires are the ones to the headlight motor. D...   Oct 3 2015, 12:15 AM
Dave_Darling   The 3 wires are the ones to the headlight motor. ...   Nov 20 2015, 09:24 PM
toolguy   Front grounds are by the back of the headlights, r...   Oct 3 2015, 12:31 AM
arkitect   Which relay is the emergency? Connected to the t...   Nov 20 2015, 03:57 PM
dirk9141973   Which relay is the emergency? Connected to the ...   Nov 20 2015, 04:06 PM
arkitect   It seems that there is a bad relay, stuck open or ...   Nov 20 2015, 04:17 PM
arkitect   Thanks DD for your responses, much appreciated. D...   Nov 20 2015, 11:23 PM
orthobiz   Couldn't it be at the steering column? Remove ...   Nov 21 2015, 07:32 AM
arkitect   Another turn of events...was running the engine an...   Jun 14 2016, 07:13 PM
arkitect   a picture. Dave   Jun 14 2016, 07:19 PM
whitetwinturbo   :popcorn: :popcorn: :popcorn:   Jun 14 2016, 11:08 PM
- Lo-Fi Version Time is now: 26th April 2025 - 09:07 PM
