New Brakes, Another Step By Step Tutorial |
relentless |
Aug 20 2015, 08:17 PM
Member Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
I took out my '76 and while driving I could tell there was some additional drag when I depressed the clutch pedal. I pulled over and felt the wheels, and found the driver's side rear was much warmer than the other three. So, after filling with E-free gas, I drove home and put her up on blocks.
I took the rear wheels off first, and found the driver's side rotor and caliper were essentially seized - I couldn't turn the rotor at all. Since the car is almost 40 years old, and in terrific condition otherwise, I placed an order with PMB Performance for a complete brake replacement. I started by cleaning the wheel wells that had decades of dirt. Here is what the rear looked like: Attached thumbnail(s) |
relentless |
Sep 22 2015, 01:32 PM
Here is the Eastwood vacuum device I used to bleed the calipers. I have put a section of clear 3/16" ID clear vinyl tubing from the reservoir and attach it to the bleeder valve. After pumping the hand actuated lever six times or so I crack the bleeder valve open a quarter turn and keep pumping. I could see the air and old fluid being drawn out.
Lo-Fi Version | Time is now: 27th December 2024 - 12:47 PM |
