Distributor, Calling all L-Jet experts |
gfg3 |
Oct 5 2015, 01:00 PM
Never Too Old Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
While I was trying to sort out possible vacuum leaks in my '75 1.8L FI (L-Jet) engine I noticed a couple of inconsistencies in the way the PO set up the system compared to what I believe is the correct vacuum setup:
1. The distributor in my car does not have any vacuum advance mechanism or vacuum hose connections. I thought all '75 EC code engines used vacuum advance. Am I wrong? 2. There is no vacuum line to the fuel pressure regulator. Normally there is a T in the line that connects the intake manifold with the decel valve and the fuel pressure regulator. Decel valve is hooked up correctly, but the fuel pressure regulator just has the in/out fuel lines, vacuum port is open. Can it work correctly like this? George |
Dave_Darling |
Oct 6 2015, 12:28 PM
914 Idiot Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
D-jet does not reference its fuel pressure to manifold pressure, there is no vacuum line connected to the regulator. (Perhaps they hadn't given that aspect any thought when they designed it?)
Since the pressure in the manifold is highest at WOT, I am pretty sure that the fuel pressure in the L-jet cars is higher at WOT than at idle. The object of the manifold-referenced fuel pressure regulator is to keep the pressure drop across the injector constant. The original distributor on an L-jet car should have a vacuum dashpot on it. If there is no provision on yours for a dashpot, it may not be the right one. (I could be wrong about the part number.) That said, you don't specifically need the correct distributor to run the engine, the way you do with D-jet. Since L-jet takes its "time to inject" signal from the ignition points, it can work off a standard distributor. If you have the (cheap) "009" distributor, you might wind up having to replace it or modify the advance curve in order to get everything working as well as possible. (The stock 1.8 distributor also has a Bosch part number ending in "009", hence my possible confusion.) --DD |
ChrisFoley |
Oct 6 2015, 12:52 PM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Since the pressure in the manifold is highest at WOT, I am pretty sure that the fuel pressure in the L-jet cars is higher at WOT than at idle. The object of the manifold-referenced fuel pressure regulator is to keep the pressure drop across the injector constant. The manuals all say the pressure goes up as manifold vacuum decreases, as you said Dave. However, I vaguely remember making measurements on a car where the opposite was the case, and the engine ran properly. (Maybe it wasn't an L-jet Type 4 and I'm mis-remembering.) |
Lo-Fi Version | Time is now: 20th June 2024 - 05:31 AM |
