Shift Rod Bushing (In tunnel by the firewall), 914-424-224-03 Very small play (Is this normal?) |
ndfrigi |
Oct 6 2015, 10:32 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi Teeners,
I got two separate order from two different vendors of the bushing because the 1st one I got seems to have a very small play when I test fit the bushing to the shift rod. So I was thinking the vendor sent me a wrong bushing. I order another one but now when I test fit it again to the shift rod, the same play I'm getting. Both bushing from two different vendor has the same part number 914-424-224-03 indicated on both plastic bag. It this the right shift rod bushing by the firewall? My shift rod diameter is very much straight. My old one that I removed has the same fitment or play with the new bushing. Thanks again! |
stugray |
Oct 7 2015, 05:59 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
A grind in rev or getting into first can often mean you just need to tighten the clutch cable.
My last tranny had exactly the troubles you are mentioning (trouble downshifting to 2nd). When I cracked it open, it had a broken bearing on the main shaft. |
EdwardBlume |
Oct 7 2015, 07:02 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
A grind in rev or getting into first can often mean you just need to tighten the clutch cable. My last tranny had exactly the troubles you are mentioning (trouble downshifting to 2nd). When I cracked it open, it had a broken bearing on the main shaft. I had the same.. a broken main bearing. Lots of fun to get off... |
Lo-Fi Version | Time is now: 25th June 2024 - 09:43 PM |
