> BUILD-OFF CHALLENGE: Madmax914, '74 914 Subaru Turbo Conversion
madmax914
post Oct 1 2015, 11:36 AM
The car is a ’74 1.8L presently on jack stands with both front and rear suspensions removed. Motor and transaxle is removed with plans for a Subaru conversion. Driver side floor pan under the seat has rust which I plan on replacing and of course the battery tray is rusted pretty badly. This was an A/C car so the front trunk had been cutout which I have tacked in a replacement panel from Restoration and Design. The body itself has been blasted and a sealer coat of primer has been applied to protect the metal, by no means is ready for paint by my standards. The underside of the car is as it was from the factory 41 years ago. I have a little surface rust in the trunk area, which is remarkable considering it has spent most of its life in the Pacific Northwest.
My plans are to convert the drive train to a Subaru motor (turbo) & transmission. I will attempt to use the Outfront Motorsport header which relocates the turbo to the front of the motor. I also plan on fabricating a bulkhead type motor mount in the front to give me more room for the exhaust. I have already purchase all the parts for a 911 suspension including Bilstein coil over front struts. Wide body is a must and at this point I am really considering going wider that the GT fender widths. The car will sit as low as possible at a height that will allow it be driven on the streets. Many of the body panels will be replaced for fiberglass to lighten the car. All bodywork and paint(not my first rodeo but not an expert either), will be handled by myself since I’m too cheap to pay someone else to do it. As for the interiors it needs a complete overhaul and I’ll modify with Sparco/Recaro type seats and possibly do Auto Meter type gauges. I would like this car to meet the criteria most would think of when describing it as a true “Outlaw” car.
BTW when you see my picture it will be clear why I call myself madmax914.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
JRust
post Oct 10 2015, 12:28 PM
Hey Brett are you using the stock oil pan? I'm going to be changing mine. Outfront basically cuts the stock one down & welds on a new bottom. A little more to it but it get's closer to like 4 1/4" as opposed to the 6 1/2" or so stock. Only thing I don't like is losing some oil capacity with it. Small car has a nice aluminum one which I think I prefer. Keeps the stock oil capacity. Which has to mean its a litter bigger around. So just not sure if it will fit with my cradle. I think I have a little space to work with there. Anyway feel free to buy the small car mount for yours. Then I can borrow it to see if it will fit mine (IMG:style_emoticons/default/happy11.gif)
madmax914   BUILD-OFF CHALLENGE: Madmax914   Oct 1 2015, 11:36 AM
madmax914   This is the motor, 2004 2.0L WRX turbo motor with ...   Oct 1 2015, 11:43 AM
JRust   This is the motor, 2004 2.0L WRX turbo motor with...   Oct 1 2015, 07:14 PM
Andyrew   Should be fun to watch this one!   Oct 1 2015, 07:07 PM
914forme   Oh wow this will be a fun one to watch, another su...   Oct 1 2015, 08:06 PM
Mueller   A conversion?...not fair, they get more points...h...   Oct 2 2015, 11:10 AM
Nutter965   Mmm this is going to be sweet, nice looking shell ...   Oct 2 2015, 01:32 PM
madmax914   Here is my Outfront coated header and the stock tu...   Oct 2 2015, 06:55 PM
madmax914   Just finished up making a couple parts for the bul...   Oct 4 2015, 04:49 PM
dangerranger01   Right on! Another oregon build....i'm exci...   Oct 4 2015, 08:06 PM
madmax914   Right on! Another oregon build....i'm exc...   Oct 4 2015, 08:31 PM
914forme   Nice looking engine mount. Should work fine, lots...   Oct 5 2015, 07:16 AM
Chris H.   I'm thinking the same thing... :idea: I like t...   Oct 5 2015, 01:42 PM
madmax914   Taking the night off from working on the car, loca...   Oct 6 2015, 07:15 PM
Andyrew   Widmer's got some good stuff!   Oct 6 2015, 09:35 PM
Garland   I'm sure this has been discussed several time...   Oct 9 2015, 06:13 PM
JRust   Hey Brett are you using the stock oil pan? I'm...   Oct 10 2015, 12:28 PM
madmax914   Hey Brett are you using the stock oil pan? I...   Oct 10 2015, 12:56 PM
JRust   The Outfront oil pan and header was the first thi...   Oct 10 2015, 02:10 PM
madmax914   It doesn't the pans about 1-1/2" below th...   Oct 10 2015, 02:23 PM
madmax914   I have the motor and transmission in place so I ca...   Oct 13 2015, 09:56 PM
porsaru   I have the motor and transmission in place so I c...   Nov 13 2015, 11:46 AM
madmax914   I have the motor and transmission in place so I ...   Nov 13 2015, 01:58 PM
Andyrew   Pretty nice fitment! What are you going to do ...   Oct 13 2015, 10:27 PM
madmax914   Pretty nice fitment! What are you going to do...   Oct 13 2015, 10:37 PM
914GTSTI   What is your idea for the motor cradle ? Randy   Oct 13 2015, 10:49 PM
madmax914   What is your idea for the motor cradle ? Randy I...   Oct 13 2015, 10:59 PM
flmont   whats the cost,..and pwr of a motor like that ...   Oct 14 2015, 10:26 PM
madmax914   whats the cost,..and pwr of a motor like that ...   Oct 15 2015, 08:51 AM
Chris H.   I'm sure you're going to show is, but what...   Oct 15 2015, 10:38 AM
madmax914   I'm sure you're going to show is, but wha...   Oct 15 2015, 11:10 AM
Chris H.   Yeah I can picture that. Then the whole underside...   Oct 15 2015, 11:37 AM
madmax914   That is the beauty of it all, nothing to interfere...   Oct 15 2015, 11:55 AM
914forme   Yes that is what I am liking about this design. A...   Oct 15 2015, 12:00 PM
madmax914   Yes that is what I am liking about this design. ...   Oct 15 2015, 12:12 PM
JRust   Before I started this, I over analyzed it quite a...   Oct 15 2015, 12:22 PM
madmax914   Before I started this, I over analyzed it quite ...   Oct 15 2015, 02:04 PM
JRust   When I bought the OF header I also bought an exha...   Oct 15 2015, 04:43 PM
madmax914   Finished the front bulkhead motor mount.   Oct 25 2015, 07:19 PM
madmax914   If you look close you can see the Small Car motor ...   Oct 25 2015, 07:23 PM
madmax914   It's difficult to see but the oil pan is just ...   Oct 25 2015, 07:33 PM
Mueller   Nice looking mount!   Oct 25 2015, 07:51 PM
madmax914   Nice looking mount! Thank you, it is working...   Oct 25 2015, 08:35 PM
Andyrew   Good job on the mount!   Oct 25 2015, 09:54 PM
mgp4591   The mount looks pretty slick! What did OF char...   Oct 25 2015, 10:41 PM
madmax914   The mount looks pretty slick! What did OF cha...   Oct 25 2015, 10:54 PM
madmax914   I'm a little disappointed to announce that sin...   Jan 11 2016, 04:15 PM
Gmanscott55   I'm a little disappointed to announce that si...   Feb 26 2016, 08:01 AM
madmax914   I'm 100% and back at it, Just bought a FG body...   Feb 26 2016, 11:29 AM
914forme   Hope all is going better such nice workmanship on ...   Mar 20 2016, 06:51 PM
JRust   Whats going on? Haven't seen any progress budd...   Aug 18 2016, 11:57 AM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:32 AM
