Painted into a corner, Need advice on how to do it |
worn |
Oct 11 2015, 04:44 PM
can't remember Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hi to all, especially you experts with a spray gun. I know who some of you are, and you know whom the other are.
I have now painted a few cars and since I stick to single stage and can color sand, it has worked out pretty well. Especially the easy parts. What I haven't figured out is how to deal with inside corners. I understand that physics is against me, in that a ball or beam of light hitting a ninety degree inside corner wil come straight back at the sender. On inside corners, I sometimes cannot get coverage unless I settle for granular balls of paint that settle in the region. Tightening the pattern by closing the side jets that make the brush pattern for the gun seems to help as does using the smallest gun possible. I suspect though that expert advice would be better than my muddling through. Winter is closing in fast, so you have till spring to answer. Still, realistically you will have forgotten long before that, so please help me now instead. I am using bare metal, covered with DP50, followed by K36 sanded, followed by Deltron. It is Bahia red, so it looks pretty much like a major crime scene when the paint is flowing. Thanks folks!! You are amazing people. |
rick 918-S |
Oct 11 2015, 06:01 PM
Hey nice rack! -Celette Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Narrow the pattern, dust it in, When you come back over the area with a full wet coat it is less likely to collect dry spray.
worn |
Oct 11 2015, 07:02 PM
Narrow the pattern, dust it in, When you come back over the area with a full wet coat it is less likely to collect dry spray. Thanks folks. With Ricks method I can keep the main gun hooked up? Dust as in farther away, or just less trigger? Does it help to try to do each flat at a time? |
rick 918-S |
Oct 11 2015, 10:30 PM
Narrow the pattern, dust it in, When you come back over the area with a full wet coat it is less likely to collect dry spray. Thanks folks. With Ricks method I can keep the main gun hooked up? Dust as in farther away, or just less trigger? Does it help to try to do each flat at a time? What area are you painting? (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) A guy that paints a lot will develop an unconscious thought process. Hard to explain reflexes. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:19 PM |
