> BUILD-OFF CHALLENGE: Michigan Build, Garland, Never ending project, 8/2023 reinstalling headlamp housings
Garland
post Sep 30 2015, 10:39 PM
Restoration Fanatic
The start:
2016 Build-Off
Here I go!
I purchased the car on eBay in 1999 site unseen, and only two polorid's in the post. Looked great, sitting in a empty dusty old garage. I ask lots of questions, original paint? Factory new looking wheels? History, on and on.
He couldn't tell me anything about the car, his buddy owned it and he new nothing.
Singed over ownership 6 mts ago. He did say looks like a great car, and knows it was fast. Says 2.0 on it. 400 miles away, a buddy with a flat bed, it was worth the risk. Price was right.
On arrival, I'm on it, all over the car. Long story short the thrill is gone!
Repaint in somebody's garage, 50 footer, or a polorid. Rear end hit, hard, car pushed into something damaged the left front. Right front damage, not to bad.
Engine runs on 2 cylinders, yet it is a 2.0, with carbs. Must have been the reason for the FIRE in the engine bay. One head is trashed from the fire, and theirs nothing else to talk about, except the A/C system they must have got on eBay and hacked into the car.
(Key words: eBay, "was" fast, Polorid, and risk)
I swapped in a 1.7 and a tail shift 2.0 exchangers with triad exhaust. 1971 complete interior (had one). Plus just about every other trim part. Polished the paint, cleaned up the wheels, and I drove it. Now it's time to fix It.
MICHIGAN BUILD
(Short monthly update posts) @ Contest Link
1973 Red 1.7
5 Major Tasks to complete during the Challenge:
1. Replace back half of rear trunk floor. (Rusted, rear ended, poorly patched)
& Replace entire rear body panel, and Bumper. (Rear ended, poorly repaired)
& Patch in 1/2 left front fender. (Poorly repaired)
2. Delete headlamp doors, modify hood, and relocate headlamps.
3. Install 4 steel flares, and modify all valances. 5 lug, and wheel tire package.
4. Build up, and replace engine.
Installed now:
With:
1.7 914 Engine balanced
260 x 396 Cam .006
96mm Big Bore kit
Mallory Unlite Distributor 14004
Weber 40 DCNF (w/ very short intakes)
Air jet 1.80 Main 1.25
2.0 L exhaust
Work in progress replacement.
5. Major interior renew.
Still need to finish the engine, and start it. Purchased here from a member a few years ago.
I have a 2nd 914 that I'm also working on, and been a owner of many since the 70's. I do all my own work. My enjoyment time.
dakotaewing
post Oct 14 2015, 04:52 PM
You might consider striping all the paint off the inside of the rear panel, and priming most of it prior to welding that piece in...
it will be easier to treat the small areas of rust with the panel out as well -
Looking good!!
Garland   BUILD-OFF CHALLENGE: Michigan Build, Garland   Sep 30 2015, 10:39 PM
Garland   I replaced the hoods with ones of better quality, ...   Sep 30 2015, 11:42 PM
Cairo94507   Nice looking job. You will have a nice 914 when y...   Oct 1 2015, 06:59 AM
Garland   Thanks Michael. Well I rough trimmed and fitted ...   Oct 2 2015, 09:54 PM
Garland   Started cutting for the headlamps, and as I was pu...   Oct 3 2015, 09:19 AM
914forme   Relocating the headlights :popcorn: wondering wha...   Oct 3 2015, 05:24 PM
Philip W.   I think that snow picture should be considered for...   Oct 3 2015, 05:34 PM
stevegm   I think that snow picture should be considered fo...   Oct 3 2015, 05:39 PM
Garland   The headlamps are going to a challenge in it self....   Oct 4 2015, 08:02 AM
Garland   Scraped all carpet, glue and some seam sealer. . ...   Oct 4 2015, 08:07 AM
Garland   Then paint remover, and a rinse   Oct 4 2015, 11:25 AM
Garland   My 73 build off challenge car. "Michigan Buil...   Oct 4 2015, 12:41 PM
Mike1981   Nice Work John I always thought your Red 1.7 look...   Oct 9 2015, 06:51 PM
trojanhorsepower   John, Who made your rear trunk floor patch panel?   Oct 12 2015, 07:35 PM
Garland   Right here: Great products! They have molds...   Oct 13 2015, 11:07 PM
trojanhorsepower   Humm. I have the same one, but mine does not have...   Oct 14 2015, 09:48 AM
Garland   I bent the lip, and made the flange. I did not add...   Oct 14 2015, 04:35 PM
dakotaewing   You might consider striping all the paint off the ...   Oct 14 2015, 04:52 PM
Garland   You might consider striping all the paint off the...   Oct 19 2015, 09:31 PM
Garland   Finished up the rear early steel bumper. Needed to...   Oct 21 2015, 05:42 PM
Triaddave   Hey, Nice exhaust. give me the serial number off t...   Jan 11 2016, 01:21 PM
Garland   Hey, Nice exhaust. give me the serial number off ...   Jan 11 2016, 09:14 PM
DirtyCossack   I'm looking at bumper hole filling in my futur...   Oct 21 2015, 07:01 PM
Garland   This was never chromed, was steel painted black wh...   Oct 21 2015, 08:49 PM
Garland   Welded the rear fenders on, and the left front fen...   Nov 29 2015, 07:59 PM
Andyrew   Did you purposefully make a notch in your front pa...   Nov 29 2015, 08:31 PM
Garland   Did you purposefully make a notch in your front p...   Nov 29 2015, 10:12 PM
Garland   i finished up the front fenders, and the 3 of the ...   Dec 31 2015, 08:01 PM
wndsnd   Nice Work!   Dec 31 2015, 08:09 PM
Garland   The side valance has to be more then bent to fit. ...   Dec 31 2015, 08:18 PM
Garland   Done with the side's. I feel that they will wo...   Dec 31 2015, 08:31 PM
914forme   Nice Work, looking very good.   Dec 31 2015, 08:55 PM
Garland   Now for the rear. I have a snow plow/scoop and hav...   Dec 31 2015, 09:45 PM
Garland   And the last adjustment and fit. 3 done: J...   Dec 31 2015, 09:46 PM
Garland   All 3 done, now to change to 5 lug. And Turbo tie ...   Dec 31 2015, 10:29 PM
Andyrew   Great metal work there! That looks very well d...   Jan 1 2016, 10:40 AM
mbseto   Nice work, looks like quick progress!   Jan 1 2016, 11:36 AM
Flipczak   Looks good, can't wait to see the finished pro...   Jan 8 2016, 05:46 PM
Andyrew   Looks good, can't wait to see the finished pr...   Jan 11 2016, 01:30 PM
Old Yella   I like how you didn't complain about the origi...   Jan 11 2016, 05:17 PM
Chris H.   I agree, nice metal work :beer2: . You make it l...   Jan 11 2016, 10:47 PM
twistedstang   Nice work and great pics! Following along in c...   Jan 12 2016, 06:59 AM
whitetwinturbo   :popcorn: :sawzall: :welder:   Jan 12 2016, 11:12 AM
Garland   Back at it over the last few weeks, installed 5 Lu...   Jan 27 2016, 08:28 PM
whitetwinturbo   Back at it over the last few weeks, installed 5 L...   Mar 31 2016, 10:19 PM
Garland   I will be using spacers 2mm rear, and 15-20mm fron...   Jan 27 2016, 08:36 PM
914forme   very nice work sir, very nice.   Jan 27 2016, 08:45 PM
Vysoc   Wow John, I am very impressed with what you have ...   Jan 28 2016, 04:03 PM
Puebloswatcop   It looks like the same "hack" did my rea...   Jan 30 2016, 08:09 AM
Garland   Put together the rear struts. Old pair of Koni red...   Jan 31 2016, 12:01 PM
rick 918-S   Nice work. Fat rubber.   Jan 31 2016, 11:22 PM
Garland   Well, still on it. Worked on the hood to eliminate...   Feb 29 2016, 09:05 PM
trojanhorsepower   Man you are making great progress, and it looks gr...   Mar 1 2016, 06:49 AM
whitetwinturbo   :smash: :welder: :smash: :worship:   Mar 1 2016, 10:11 AM
914forme   Nice hood work there :headbanger:   Mar 1 2016, 10:48 AM
Garland   Thanks everybody, I have slowed down a bit wi...   Mar 2 2016, 07:57 PM
Garland   Change in plans. Im back working on the headlamps....   Mar 31 2016, 07:55 PM
mgp4591   Okay, this looks really interesting.... :idea: :p...   Mar 31 2016, 08:06 PM
Garland   Thank you, and on with the show :popcorn: Posit...   Mar 31 2016, 08:07 PM
Andyrew   Interesting! I take it you dont have headlight...   Mar 31 2016, 08:15 PM
Garland   I have thought about that, and have a solution in ...   Mar 31 2016, 08:17 PM
Garland   Yes and theres a picture of it installed also.   Mar 31 2016, 10:48 PM
whitetwinturbo   ...........I must have missed the installed pic......   Mar 31 2016, 10:52 PM
Garland   ...........I must have missed the installed pic.....   Apr 1 2016, 07:05 AM
whitetwinturbo   [quote name='whitetwinturbo' post='2323387' date=...   Apr 1 2016, 12:41 PM
Garland   Here is a idea that I tried, and it worked. The to...   Apr 1 2016, 01:58 PM
whitetwinturbo   :idea: :idea: :idea:   Apr 1 2016, 02:02 PM
Garland   Headlamps on hold, still working out the bugs. On ...   Apr 30 2016, 10:29 PM
Garland   Steam seemed the best idea, so out with the tea po...   Apr 30 2016, 10:40 PM
Garland   Finishing up Using a early interior, living i...   Apr 30 2016, 10:49 PM
Garland   Headlamps have become a daunting task. Each time I...   Jul 4 2016, 10:41 PM
Garland   Spent free time on the flares, and valances. Litt...   Jul 4 2016, 11:06 PM
Andyrew   Lookin good! That texture is nice!   Jul 4 2016, 11:58 PM
Olympic 1.7   Lookin good! That texture is nice! :a...   Jul 5 2016, 06:35 AM
914forme   :agree: thats what I love about build threads, get...   Jul 5 2016, 08:46 AM
Garland   When spraying the Transtar, you can achieve differ...   Jul 5 2016, 04:45 PM
Garland   Thank you to all that are following, and or commen...   Jul 23 2016, 08:58 AM
Garland   OK, well here's a few sample cuts, drills, and...   Jul 23 2016, 09:11 AM
Garland   Here I go   Jul 23 2016, 11:01 AM
Darren C   I can't bear to look.......That wood bit could...   Jul 23 2016, 01:16 PM
76-914   I can't bear to look.......That wood bit coul...   Jul 24 2016, 08:54 AM
Garland   Slow, and easy......don't want the bit to heat...   Jul 23 2016, 02:49 PM
jmitro   yea, get a real hole saw.   Jul 24 2016, 08:43 AM
Garland   Start to finish 10 minutes per cut. Shaving off ju...   Jul 24 2016, 10:07 AM
whitetwinturbo   :popcorn: :popcorn: :popcorn: :popcorn: :popco...   Jul 24 2016, 01:35 PM
Darren C   Too scary for me... ;-) Well done! Now, how ...   Jul 24 2016, 01:43 PM
Garland   :idea: Thinking brutal, but can make a mess. So w...   Jul 24 2016, 02:29 PM
raynekat   Those are definitely some "mad" skil...   Jul 24 2016, 04:05 PM
mb911   Looking good interested in how the rockers look co...   Jul 24 2016, 03:00 PM
whitetwinturbo   REALLY nice lighting :beer1: :beer1: :beer1:   Jul 24 2016, 03:01 PM
Andyrew   Awesome headlight solution! But... Why did y...   Jul 24 2016, 03:24 PM
Garland   Awesome headlight solution! But... Why did ...   Jul 24 2016, 04:26 PM
Garland   I ran in to a bit of a problem when starting my bu...   Aug 7 2016, 01:15 PM
Garland   I'm Back from the "Garage" engine is...   Aug 13 2016, 10:05 AM
Garland   First here is a few pictures of my home powder coa...   Aug 29 2016, 10:00 PM
Garland   Still on its way out. A few items I had...   Aug 29 2016, 11:06 PM
Garland   installed a jumper to fool the fuel pump relay. ...   Aug 29 2016, 11:15 PM
Garland   First start in car looks good, the oil pressure is...   Aug 29 2016, 11:20 PM
914forme   Big day for sure, great job. I lost a Black and D...   Aug 30 2016, 05:31 AM
Garland   Well that took a while. Now I need to decide if I...   Aug 30 2016, 06:34 AM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 3rd April 2025 - 01:42 PM
