> another oil temp question ...
post Sep 21 2004, 09:09 PM
Resident German
sooooo, i decided today to hook up the stock oil-temp gauge (the little one without numbers).
i tested the gauge (werks fine), i tested the wire all the way back to the sender, werks fine too.
i could NOT test the sender itself (duh, it's *IN* the engine right now).
then i took her for a drive, ran some errands, just around town, for about 30 minutes, no freeway or otherwise particular hard driving.
my question is:
what kind of oil temp should i see on a 80 deg. day after 30 minutes cruising around town ???
anyone here who can give me any references? (IMG:style_emoticons/default/confused24.gif)
the needle barely made it about 5mm to the right of the first white stripe.
that would indicate the engine wasn't even up to operating temps.
can this be right??? oh, forgot to mention, the thermostat is removed, full airflow to the oil-cooler at all times.
thanks,
(IMG:style_emoticons/default/smile.gif) Andy
Mark Henry
post Sep 21 2004, 09:38 PM
that's what I do!
I did two 40 min runs today at around 70F outside temp. I do have a T-stat but that shouldn't matter after warm-up
Run #1 was at about 70 to 80 mph and my gauge was 1/3 of the way up.
Run #2 was at about 80 to 100 mph and my gauge was 1/2 of the way up.
SirAndy   another oil temp question ...   Sep 21 2004, 09:09 PM
bernbomb914   I cant answwer your question but I have one of my ...   Sep 21 2004, 09:22 PM
Mark Henry   I did two 40 min runs today at around 70F outside ...   Sep 21 2004, 09:38 PM
Aaron Cox   andy, a 30 minute run (my gauge is in the dash 914...   Sep 21 2004, 09:40 PM
SirAndy   <...   Sep 21 2004, 09:55 PM
smg914   Andy, You didn't specify which temp gauge you...   Sep 21 2004, 10:26 PM
phantom914   Andy, My cooling flaps are stuck open and it seem...   Sep 21 2004, 10:26 PM
tiim5   Sorry to be kinda off topic, I want to install a 2...   Sep 21 2004, 11:42 PM
Bleyseng   That stock oil temp sender and taco plate work wel...   Sep 22 2004, 07:40 AM
Demick   All of the talk about 1/3 or 1/2 of the way up the...   Sep 22 2004, 08:33 AM
Rockaria     Sep 22 2004, 09:00 AM
!     Sep 22 2004, 09:53 AM
BMartin914   I had a similar question when I first got my car. ...   Sep 22 2004, 03:12 PM
larryM   a lo-o-o-ng while back Panorama had an article on ...   Oct 12 2004, 10:05 PM
ThinAir914   That Pano article would be very helpful.   Oct 12 2004, 10:11 PM
Joseph Mills   <...   Oct 12 2004, 11:15 PM
blaize   I hooked up my console temp gauge over the weekend...   Oct 12 2004, 11:33 PM
ThinAir914
  Nov 10 2004, 01:20 AM
mudfoot76   Are the temp senders easily distinguishable? I don...   Nov 10 2004, 08:14 AM
synthesisdv   My experience... Converted a 911 dual gauge to re...   Nov 10 2004, 08:49 AM
larryM   914 high oil temperature Bruce Anderson National...   Mar 2 2005, 04:41 PM
!   Gauges and senders are what ? 200 bucks max for pr...   Mar 2 2005, 04:47 PM
MecGen   You know... I am a wrench twister for a living, so...   Mar 2 2005, 05:06 PM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:41 PM
