> BUILD-OFF CHALLENGE: Budk – Bumblebee, Rustoration
budk
post Oct 4 2015, 05:00 AM
Yes! It's a Bumblebee!
This car was found in a garage in Columbus in 2010. A member here, Tornik550 posted in the forum that he found it at a garage sale and that it may be an LE.
He wasn’t interested so I went and looked at it and brought it home. It turned out to be an LE and this is what it looked like when I got it home.
Someone suggested I contact Dr. Evil who was lived about 15 miles from me. Mike came over and we pulled the engine and tranny as well as other parts while he assured me that he knew where everything belonged. Mike rebuilt the tranny and then, long story short, life got in the way for both of us, a couple of years went by and Mike ended up moving to Ohio. Before Mike moved, I realized that he was going to be too busy growing his family and his practice and I didn’t know anything about these engines so I put an ad on the Pittsburgh Craigslist looking for an air cooled engine enthusiast to help me finish put the engine together that Mike and I had torn apart. The ad stated that my preferred choice of payment was beer and that I kept the fridge in the garage full.
I got a couple of replies with suggestions of books/videos to buy but then I heard from a guy who lives a little over an 1.5 hr drive from me. It turns out that he is a 914world member and I believe he has had something like 6 of these cars over the years. His name is Ray (reharvey) but I refer to him as my Mentor. Ray drove down and we developed a list of parts to buy to finish rebuilding the engine. A few months later, after a couple of trips, the case was back together with new bearings, cam and 2056 piston/cylinders but minus the injection, wiring harness, most of the tin and a few other parts. All the original parts that were taken off were kept since this is a numbers matching car.
That was 2 years ago. Nothing else got done in 2014 and now that 2015 is winding down it is time to get back to working on the car… and this challenge is the perfect motivation. The car will need the floor and firewall patched, door sills, longs and a few other pieces including work around the front marker lights. Are new fenders available? One of the PO’s had some work done (poorly) on the sills and the longs so I’m not sure yet what all is going to need replaced. Ray is coming down in a few days to give me his opinion on the body and I expect to be placing an order with Restoration Design soon after.
budk
post Oct 31 2015, 01:41 PM
I spent the first two weeks of October removing everything left on the car except the suspension/wheels. I wanted to have the car sitting on the wheels so that I could install some bracing in the floor area. I know that bracing will need to come out at some point but until I know which panels need replaced I want the additional support. I also decided that I want to be able to hang the doors to check the gaps as panels are replaced so I had to change where I attached the door braces so that I can fit a door with the braces in place. And, I wasn’t really happy with the door braces that I had previously made using black pipe. The pipe flexed much more than I expected so I remade the braces with some extra square tubing I had laying around.
The last 2 weeks of October were spent building a rotisserie. I went with Restoration Design’s rotisserie because I think it best fits my particular needs of wanting to be able to move it around a lot and be able roll it onto my lift if need be. $250 worth of steel got the job done but I wasn’t prepared for the amount of time it took to fabricate it and for the amount of dirt created cutting and grinding new steel with the oily mill finish on it. It was however fun welding thick steel and it gave me a reason to buy a better welding helmet. I’ve been using a Harbor Freight helmet and while I haven’t done much welding before, when I did I struggled with being able to see where I was welding. So, I bought a Hobart Pro helmet and the difference is night and day. Much easier to see, lots of adjustments and the head strap assembly works really well. I also bought a better ground clamp as the clamp that came on my Millermatic 180 was practically useless. Once I got the settings on the welder dialed in and my technique correct I was able to lay down some pretty good welds.
Once the rotisserie was attached I removed the remaining suspension and with my wife’s help we removed the entire wire harness .
So, what’s next is to strip the car of paint so I can see all the parts that need cut out. I have a guy coming out next week to soda blast it in my driveway. His business is called Stripper for Hire (Stripper for hire website)…… I’m sure I’ll be the talk of the neighborhood! I still need to put dolly wheels on the rotisserie but I am waiting for a piece of steel so I will use cheap furniture dolly’s from Harbor Freight to get the car off my lift and outside for the stripper.
budk   BUILD-OFF CHALLENGE: Budk – Bumblebee   Oct 4 2015, 05:00 AM
budk   I know this a big challenge and to have a sho...   Oct 4 2015, 05:07 AM
Olympic 1.7   Howdy neighbor. I'm about 1 1/2 hr away fro...   Oct 4 2015, 06:41 AM
budk   Howdy neighbor. I'm about 1 1/2 hr away fr...   Oct 4 2015, 07:37 AM
Olympic 1.7   Howdy neighbor. I'm about 1 1/2 hr away f...   Oct 4 2015, 09:15 AM
914forme   I keep telling myself that it is only metal - ...   Oct 4 2015, 06:57 AM
hot_shoe914   Get the job done Bud, I might need you to restore ...   Oct 4 2015, 08:51 AM
budk   Get the job done Bud, I might need you to restore...   Oct 4 2015, 12:11 PM
sfrenck   Paint the wheels black an call it an Unbumblee...   Oct 4 2015, 09:01 AM
Mueller   I really like the current paint scheme myself as w...   Oct 4 2015, 09:18 AM
Johny Blackstain   Between the Pirates, Penguins & Steelers, I...   Oct 4 2015, 09:35 AM
Olympic 1.7   Between the Pirates, Penguins & Steelers, I...   Oct 4 2015, 09:53 AM
Johny Blackstain   Couple years ago I missed on a Bumblebee that was...   Oct 4 2015, 10:05 AM
budk   Between the Pirates, Penguins & Steelers, I...   Oct 4 2015, 12:00 PM
budk   I spent the first two weeks of October removing ev...   Oct 31 2015, 01:41 PM
Andyrew   Great looking rotisserie and bracing!   Oct 31 2015, 02:36 PM
914forme   Wow that rotisserie looks like something I need fo...   Oct 31 2015, 04:37 PM
budk   Wow that rotisserie looks like something I need f...   Nov 1 2015, 05:00 PM
budk   Hera are a few pics of the car in process and a su...   Nov 5 2015, 04:24 AM
DirtyCossack   Those welds make me feel better about my own.   Nov 5 2015, 06:26 PM
budk   Car was soda blasted the first week of November. ...   Dec 1 2015, 05:16 AM
budk   All in all the soda blasting revealed that there a...   Dec 1 2015, 05:27 AM
mepstein   All in all the soda blasting revealed that there ...   Dec 5 2015, 07:57 AM
budk   [quote name='budk' post='2271790' date='Dec 1 201...   Dec 5 2015, 08:50 AM
mepstein   [quote name='budk' post='2271790' date='Dec 1 20...   Dec 5 2015, 09:02 AM
budk   [quote name='budk' post='2273634' date='Dec 5 201...   Dec 5 2015, 04:27 PM
budk   Just a :thumbsup: to the guys at Restoration Des...   Dec 5 2015, 07:22 AM
budk   Time for an update. I have to say that keeping th...   Dec 31 2015, 01:44 PM
budk   I decided to layout my wire harness on some ply...   Dec 31 2015, 01:47 PM
PlantMan   I decided to layout my wire harness on some pl...   Feb 3 2016, 02:53 PM
budk   Someone else posted that it's harder to fix so...   Jan 11 2016, 02:49 PM
Andyrew   Replace your cut off wheels before they get down t...   Jan 11 2016, 04:10 PM
budk   Replace your cut off wheels before they get down ...   Jan 11 2016, 05:36 PM
Andyrew   I have found that the fastest way to destroy a cut...   Jan 11 2016, 05:42 PM
budk   I have found that the fastest way to destroy a cu...   Jan 11 2016, 06:29 PM
krazykonrad   I guess its not original, but that yellow reverse-...   Jan 11 2016, 09:32 PM
rick 918-S   Wow, just like a Cracker Jack box. There's a s...   Jan 31 2016, 11:38 PM
budk   Adding a January update. Not much progress this m...   Feb 1 2016, 03:20 PM
Jeff Bowlsby   I did start cleaning some of the contacts on my w...   Feb 1 2016, 08:52 PM
budk   I did start cleaning some of the contacts on my ...   Feb 2 2016, 09:49 AM
budk   March update... nothing done this month except for...   Mar 31 2016, 01:22 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:26 AM
