Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
It's the 1.8 elbow that has multiple fittings If there is enough interest I'll make these.
Who needs one? Attached thumbnail(s) ![]() |
75914-L20C |
It isn't what you drive, but how you drive that counts. ![]() ![]() Group: Members Posts: 57 Joined: 29-November 05 From: MN, USA Member No.: 5,204 Region Association: Upper MidWest ![]() |
Cool! I was about to suggest that you reproduce this part! This, plus a $1000 2.0L rebuild kit. (J/K (IMG:style_emoticons/default/smile.gif) )
I have 2 styles of the intake elbow here. 022.129.967T has a larger (~24mm) upper fitting hole and the 022.129.967 (no T) has a smaller (~16mm) fitting hole. I have the 022.129.967T on my '75 1.8L. I don't know what uses the non-T part. I am definitely in for the 022.129.967T with the larger upper fitting. - Pete 022.129.967T above, 022.129.967 below ![]() |
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
Cool! I was about to suggest that you reproduce this part! This, plus a $1000 2.0L rebuild kit. (J/K (IMG:style_emoticons/default/smile.gif) ) I have 2 styles of the intake elbow here. 022.129.967T has a larger (~24mm) upper fitting hole and the 022.129.967 (no T) has a smaller (~16mm) fitting hole. I have the 022.129.967T on my '75 1.8L. I don't know what uses the non-T part. I am definitely in for the 022.129.967T with the larger upper fitting. - Pete 022.129.967T above, 022.129.967 below ![]() Is it possible the picture on the bottom has the right metal tube fitting in place and despite the different part numbers, they really are the same? Looks like that picture may be perfectly looking down the barrel of the metal fitting... Paul |
Lo-Fi Version | Time is now: 24th June 2024 - 07:37 AM |
