Possible new GB 1.8 intake "Elbow Tube", B022129967 looking like $44 each ! Done and ready to ship |
Mikey914 |
Oct 30 2015, 07:27 AM
The rubber man Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
It's the 1.8 elbow that has multiple fittings If there is enough interest I'll make these.
Who needs one? Attached thumbnail(s) |
75914-L20C |
Oct 30 2015, 07:27 PM
It isn't what you drive, but how you drive that counts. Group: Members Posts: 57 Joined: 29-November 05 From: MN, USA Member No.: 5,204 Region Association: Upper MidWest |
Cool! I was about to suggest that you reproduce this part! This, plus a $1000 2.0L rebuild kit. (J/K (IMG:style_emoticons/default/smile.gif) )
I have 2 styles of the intake elbow here. 022.129.967T has a larger (~24mm) upper fitting hole and the 022.129.967 (no T) has a smaller (~16mm) fitting hole. I have the 022.129.967T on my '75 1.8L. I don't know what uses the non-T part. I am definitely in for the 022.129.967T with the larger upper fitting. - Pete 022.129.967T above, 022.129.967 below |
orthobiz |
Nov 1 2015, 09:28 AM
Senior Member Group: Members Posts: 1,755 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Cool! I was about to suggest that you reproduce this part! This, plus a $1000 2.0L rebuild kit. (J/K (IMG:style_emoticons/default/smile.gif) ) I have 2 styles of the intake elbow here. 022.129.967T has a larger (~24mm) upper fitting hole and the 022.129.967 (no T) has a smaller (~16mm) fitting hole. I have the 022.129.967T on my '75 1.8L. I don't know what uses the non-T part. I am definitely in for the 022.129.967T with the larger upper fitting. - Pete 022.129.967T above, 022.129.967 below Is it possible the picture on the bottom has the right metal tube fitting in place and despite the different part numbers, they really are the same? Looks like that picture may be perfectly looking down the barrel of the metal fitting... Paul |
davesprinkle |
Nov 1 2015, 10:38 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Is it possible the picture on the bottom has the right metal tube fitting in place and despite the different part numbers, they really are the same? Looks like that picture may be perfectly looking down the barrel of the metal fitting... Paul No. This is not an optical illusion. I can confirm there are two different elbows. They differ in the diameter of that port. The large port version is from '75 & '76. The small port version is '74. I used a large-port version on my '74, but had to get a fitting manufactured to step down the diameter so that my vent line would fit. |
Lo-Fi Version | Time is now: 28th June 2024 - 08:55 AM |
