Distributor Pull, /6 |
EdwardBlume |
Nov 1 2015, 10:26 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I need to pull the distributor on the 2.4 /6, but it won't come out. I have it at TDC #1, with the rotor pointing at 1. Took the bolt off the adjuster and can move it back and forth, but the whole assembly will not come up and out.
Any ideas? |
porschetub |
Nov 2 2015, 01:41 AM
Advanced Member Group: Members Posts: 4,764 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I need to pull the distributor on the 2.4 /6, but it won't come out. I have it at TDC #1, with the rotor pointing at 1. Took the bolt off the adjuster and can move it back and forth, but the whole assembly will not come up and out. Any ideas? reach in there with the base plate done up (case nut off ) and work a fine screwdriver under there ,the shaft seal is stuck,sorry but you have to be a little rough ,I think the Pelican part seal for most 914's is the same but not 100% sure. I think you mentioned on you had an issue with yours sticking up ,Iam thinking your advance plate is gummed up so try a good spray of brake cleaner before you take it apart...may work,hope so because parts are hard to find, (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 14th January 2025 - 06:15 AM |
