another oil temp question ... |
SirAndy |
Sep 21 2004, 09:09 PM
Resident German Group: Admin Posts: 41,961 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
sooooo, i decided today to hook up the stock oil-temp gauge (the little one without numbers).
i tested the gauge (werks fine), i tested the wire all the way back to the sender, werks fine too. i could NOT test the sender itself (duh, it's *IN* the engine right now). then i took her for a drive, ran some errands, just around town, for about 30 minutes, no freeway or otherwise particular hard driving. my question is: what kind of oil temp should i see on a 80 deg. day after 30 minutes cruising around town ??? anyone here who can give me any references? (IMG:style_emoticons/default/confused24.gif) the needle barely made it about 5mm to the right of the first white stripe. that would indicate the engine wasn't even up to operating temps. can this be right??? oh, forgot to mention, the thermostat is removed, full airflow to the oil-cooler at all times. thanks, (IMG:style_emoticons/default/smile.gif) Andy |
BMartin914 |
Sep 22 2004, 03:12 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I had a similar question when I first got my car.
The gauge was almost pegging with normal driving conditions. Found out from the PO that the sender is a low temp -- pegs at 230' Your sender type is a very integral part of the oil temp gauge. I would check it out to make sure your gauge and sender match. Ben |
Lo-Fi Version | Time is now: 6th January 2025 - 08:43 PM |
