Can you run a EJ20 Turbo as a N/A engine, then install the turbo later,.. |
flmont |
Nov 5 2015, 05:39 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Iam now thinking about running a turbo EJ20,..but can it be run as a NA,.Until I could put all the componets together,..meaning Fabing all the parts that wont come with the engine,..or is it a drop-in assembly,..Thanks FM
Mueller |
Nov 5 2015, 06:17 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I see no reason why not...it won't be as quick as a factory N/A 2.0 Subaru motor of the same size (if they even make one) due to the lower compression of the turbo motor.
Lo-Fi Version | Time is now: 6th January 2025 - 09:55 PM |
