Can you run a EJ20 Turbo as a N/A engine, then install the turbo later,.. |
flmont |
Nov 5 2015, 05:39 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Iam now thinking about running a turbo EJ20,..but can it be run as a NA,.Until I could put all the componets together,..meaning Fabing all the parts that wont come with the engine,..or is it a drop-in assembly,..Thanks FM
flmont |
Nov 5 2015, 06:45 PM
I cant find a ez30 motor yet ,so I thought about those engines,seems to Be enough available,... how are the JDM engines..????
76-914 |
Nov 5 2015, 09:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,652 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I cant find a ez30 motor yet ,so I thought about those engines,seems to Be enough available,... how are the JDM engines..???? You'll probably end up w/ a JDM which is OK if you can get the ECU too. Otherwise, buy a nice wrecked one and strip. There is so much you can cannibalize. |
Lo-Fi Version | Time is now: 6th January 2025 - 10:24 PM |
