DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,819 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Introduction to the car my 11 year old named black beauty . Hopefully it can be returned to her former glory.
Back story: Not much is kknown about this car. I bought the car from Billh1963 on Sept. 29, 2015. He bought the car earlier in the year , found on Craigs list in Columbia, SC. We all know Bill can't pass up a deal!. Car sat for 10 years after the p.o. had pulled it off the road to fix and restore it. He got as far as stripping it down, pulled out much of the wiring harness. Replaced the right front quarter panel and then it was abandoned. Luckily it was preserved by being stored in a clean dry place. Goals: return to road as a nice close to original daily driver. 1. Remove rust in hell hole and passenger cross member, and sail panel area on left side. 2. Prepare for back dating bumpers 3. Clean and prep for repainting. 3.5. Assess motor status and prepare for refresh. Either a. Refresh 1.8 , b.rebuild using current motor with turbo, or c. Replace with 2.0 from donor car. 4. Paint 5. Reassemble and complete restore of interior. Interior was originally white, now dyed black and in bad shape. Not salvageable. Here are a few pictures of the current condition of the car. I am a late entry and thank the powers that be for allowing me to join the contest. I do not have the welding or body work talent that some have but I will do most if not all mechanical and interior restore work. Attached thumbnail(s) ![]() ![]() |
DRPHIL914 |
New distributor.
Can I use this over ? I think when the pulled it out it was ruined, I may need to source a new one, do they make new column parts? Attached thumbnail(s) ![]() ![]() |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
DRPHIL914 |
New distributor. Can I use this over ? I think when the pulled it out it was ruined, I may need to source a new one, do they make new column parts? The split you mean? Thats normal, it actually pieces back together. The question is if everything works.. gotcha, it was taped , the little clips that catch to hold it together are snapped off, - going to test it out, but I have a line on a NOS one from 914sixer, - I might do the column back date to use the one that has the connectors that fit the 911 intermittent and electric pump switch then install a electric washer pump. - it never ends does it!- one question as this thing was in pieces, there were some pins and I don't know where they go. I guess the only way to know if this one will work is to re-install it and hook up the connectors? I don't eve have lights, blinkers, horn, or wipers connected, since the car was already stripped down before I bought it, so that will have to wait until reassembly begins! |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:25 AM |
