Wiring Harness Questions for My Suby Swap, I have ecu pins i need to figure out |
tazz9924 |
Nov 6 2015, 12:08 PM
Senior Member Group: Members Posts: 716 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Hello 914 world! Im doing a suby swap into my 914 and ive ran into a stopping point. I have pins on my ej205 ecu i dont know what to do with them. With the wealth of suby swap knowledge on 914 world I figured someone could help!
my issue pins: vehical speed signal radiator fan relay 1/2 control engine speed output fuel tank pressure sensor fuel tank pressure control solonoid drain valve fuel tank sensor control valve fuel level sensor fuel temp sensor signal test mode connector line end check 1 sorry if its a poop ton of stuff but any help you can spare is greatly appreciated. Thanks! |
Lo-Fi Version | Time is now: 6th January 2025 - 05:06 PM |
