Factoru 914-6 fuel pump with low pressure, Has anyone taken one apart and fixed them. |
toolguy |
Nov 21 2015, 08:49 PM
Senior Member Group: Members Posts: 1,273 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
I've got an original 6 with the factory fuel pump. . after sitting for 6 months, the pump runs but has low fuel pressure on the carb side. . Has great pressure on the tank return side. .no line obstructions. . . tested out of the car. . . won't lift fuel over level in the tank. . . anyone ever tried to adjust or repair one
Read down. . . Fixed !!! Attached thumbnail(s) |
McMark |
Nov 22 2015, 07:11 AM
I was able to find the o-rings in fuel-safe Viton, and have been able to get into the pumps to replace them. But there are two MAJOR issues with resealing a pump.
1. The outer housing is crimped onto the motor. These crimps are very difficult to pry apart and even harder to reinstall. If I were to even have a hope of making a reseal job work, I would expect to make special tooling to release and make those crimps. 2. The small silver 'button' on the side is the internal pressure relief. That cover is also crimped on, so there is a similar issue to #1, but also there is a seal inside that I haven't located (or tried). The best bet is to call Fuel Injection Corp (925-371-6551). They rebuild the 914-4 pumps, including machining a new pressure relief cap (button) from solid aluminum. They should be able to rebuild your pump. Keep us posted. I have two 914-6 pumps that need rebuilding. |
rgalla9146 |
Nov 22 2015, 08:53 AM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I was able to find the o-rings in fuel-safe Viton, and have been able to get into the pumps to replace them. But there are two MAJOR issues with resealing a pump. 1. The outer housing is crimped onto the motor. These crimps are very difficult to pry apart and even harder to reinstall. If I were to even have a hope of making a reseal job work, I would expect to make special tooling to release and make those crimps. 2. The small silver 'button' on the side is the internal pressure relief. That cover is also crimped on, so there is a similar issue to #1, but also there is a seal inside that I haven't located (or tried). The best bet is to call Fuel Injection Corp (925-371-6551). They rebuild the 914-4 pumps, including machining a new pressure relief cap (button) from solid aluminum. They should be able to rebuild your pump. Keep us posted. I have two 914-6 pumps that need rebuilding. Got a couple myself. Anyone using one of the new Pierburg carb fuel pumps ? |
Mark Henry |
Nov 22 2015, 10:31 AM
Anyone using one of the new Pierburg carb fuel pumps ? The funny thing about that thread on the bird is no one really admits that they have tried the pierburg pump. George is the only peep here that states he has used them. Plus the only review on pelican is "I got it and ohhhh it is shiny and pretty ...can't wait to try it" And it is a 5 star review no less... QUOTE I have not installed this pump yet, but my pre-installation impression is that it is extremely well made, very small and light. I look forward to seeing it in action. WTF kind of totally fucking useless review is that (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 25th September 2024 - 10:48 PM |
