toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
I've got an original 6 with the factory fuel pump. . after sitting for 6 months, the pump runs but has low fuel pressure on the carb side. . Has great pressure on the tank return side. .no line obstructions. . . tested out of the car. . . won't lift fuel over level in the tank. . . anyone ever tried to adjust or repair one
Read down. . . Fixed !!! Attached thumbnail(s) ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I was able to find the o-rings in fuel-safe Viton, and have been able to get into the pumps to replace them. But there are two MAJOR issues with resealing a pump.
1. The outer housing is crimped onto the motor. These crimps are very difficult to pry apart and even harder to reinstall. If I were to even have a hope of making a reseal job work, I would expect to make special tooling to release and make those crimps. 2. The small silver 'button' on the side is the internal pressure relief. That cover is also crimped on, so there is a similar issue to #1, but also there is a seal inside that I haven't located (or tried). The best bet is to call Fuel Injection Corp (925-371-6551). They rebuild the 914-4 pumps, including machining a new pressure relief cap (button) from solid aluminum. They should be able to rebuild your pump. Keep us posted. I have two 914-6 pumps that need rebuilding. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I was able to find the o-rings in fuel-safe Viton, and have been able to get into the pumps to replace them. But there are two MAJOR issues with resealing a pump. 1. The outer housing is crimped onto the motor. These crimps are very difficult to pry apart and even harder to reinstall. If I were to even have a hope of making a reseal job work, I would expect to make special tooling to release and make those crimps. 2. The small silver 'button' on the side is the internal pressure relief. That cover is also crimped on, so there is a similar issue to #1, but also there is a seal inside that I haven't located (or tried). The best bet is to call Fuel Injection Corp (925-371-6551). They rebuild the 914-4 pumps, including machining a new pressure relief cap (button) from solid aluminum. They should be able to rebuild your pump. Keep us posted. I have two 914-6 pumps that need rebuilding. Got a couple myself. Anyone using one of the new Pierburg carb fuel pumps ? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Anyone using one of the new Pierburg carb fuel pumps ? The funny thing about that thread on the bird is no one really admits that they have tried the pierburg pump. George is the only peep here that states he has used them. Plus the only review on pelican is "I got it and ohhhh it is shiny and pretty ...can't wait to try it" And it is a 5 star review no less... QUOTE I have not installed this pump yet, but my pre-installation impression is that it is extremely well made, very small and light. I look forward to seeing it in action. WTF kind of totally fucking useless review is that (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/rolleyes.gif) |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Anyone using one of the new Pierburg carb fuel pumps ? The funny thing about that thread on the bird is no one really admits that they have tried the pierburg pump. George is the only peep here that states he has used them. Plus the only review on pelican is "I got it and ohhhh it is shiny and pretty ...can't wait to try it" And it is a 5 star review no less... QUOTE I have not installed this pump yet, but my pre-installation impression is that it is extremely well made, very small and light. I look forward to seeing it in action. WTF kind of totally fucking useless review is that (IMG:style_emoticons/default/WTF.gif) Yea I have reviewed and that rating drops back,there Chinese made regulator comes to mind,sent them an email regarding the fact it didn't fit properly,LOL they still list it,or I could send it back half way round the world @ my cost (IMG:style_emoticons/default/WTF.gif), Then I asked why they have a 914/6 conversion section when a large percentage of the parts are NLA ,they said they would review that.......nothing done. Having said all this they are best of a bad bunch really,still my main supplier and they seem to be generous with discount codes,they have most hard parts if not I go to Stoddards. Unless you are a really set on the correct pump I wouldn't bother reconing or buying a rebuilt unit, its well documented about failure of rebuilt units......maybe cause they are just old and were never made to be rebuilt,the Carter LP unit has a good rep. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 07:20 AM |
