jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
Thought I would start a new thread for all to view and learn from.
Got the muffer and muffler bracket off for a better view. Check out the arrow below the hole?? more failure in case? Went ahead and drained the oil. Hope I don't find too much metal. Tomarrow I will start unbuckling everything so i can drop the tranny lower. Then we'll peer into the abyss..... (IMG:style_emoticons/default/sad.gif) later Attached image(s) ![]() |
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
Uh, guys, that is the speedo drive gear that _DRILLED_ its way through the rear case. Either the pinion bearing failed or the large nut at the end of the pinion shaft was not tightented, came loose and machined a hole in the case.
In either case, the rear cover is hosed. Get the rear cover from your tailshift tranny and install. Or better yet, do a sideshift conversion on your old tranny and take the best parts from the two. If the bearing is OK, you will still need to replace the big nut/worm drive. It takes a 30mm socket. James |
Lo-Fi Version | Time is now: 18th June 2024 - 07:32 AM |
