Stock CV Joint Angle of Degree Articulation, Is More Better for a Stock Axle? |
914Sixer |
Dec 1 2015, 08:51 PM
914 Guru Group: Members Posts: 8,918 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I went over to Blind Chicken Racing and looked up CV Joints 101. The 914 CV is a slightly modified Type 1 joint. Type 1 shows to have 12 degrees of articulation. Going to update to 911SC rear stubs and hubs requiring 100mm CV joints. Type 4, Thing 181, 924/944 are all 100mm with 22 degrees of travel. VW Bus and Vanagan are 100mm too but with 17 degrees of travel.
Bus CV joints are about 1/2 the price of 924/944 with 5 degrees more travel than the stock 914. Any reason they would not be more than heavy duty enough for the job? |
DBCooper |
Dec 1 2015, 09:01 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Yes, stronger and cheaper. I don't know but suspect they make the joints with larger angles stronger because they're on heavier cars that generally have more suspension travel. When I put in the Subaru transmission I used 100mm bus CV's on the inside and 914 outers. Idea was to leave a weak link that would break before the transmission, and in fact I've broken a LOT of 914 CV's, never one of the bus's. It's probably protected things but it's been a lot of work, so I'm ready to ditch the 914 CV's on the outside in favor of bus both in and out.
Lo-Fi Version | Time is now: 24th June 2024 - 07:54 AM |
