Stock CV Joint Angle of Degree Articulation, Is More Better for a Stock Axle? |
914Sixer |
Dec 1 2015, 08:51 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I went over to Blind Chicken Racing and looked up CV Joints 101. The 914 CV is a slightly modified Type 1 joint. Type 1 shows to have 12 degrees of articulation. Going to update to 911SC rear stubs and hubs requiring 100mm CV joints. Type 4, Thing 181, 924/944 are all 100mm with 22 degrees of travel. VW Bus and Vanagan are 100mm too but with 17 degrees of travel.
Bus CV joints are about 1/2 the price of 924/944 with 5 degrees more travel than the stock 914. Any reason they would not be more than heavy duty enough for the job? |
Dave_Darling |
Dec 3 2015, 10:29 AM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think the spline count is the same between the Type I CVs and the 914 ones as well. The only difference that I can recall is that you either have to convert the flange over to 6-bolt attachment, or convert the CV to 4-bolts and two roll pins.
I think the Bus CVs may be the same, but I'm not sure. --DD |
Lo-Fi Version | Time is now: 28th December 2024 - 02:13 PM |
