Stock CV Joint Angle of Degree Articulation, Is More Better for a Stock Axle? |
914Sixer |
Dec 1 2015, 08:51 PM
914 Guru Group: Members Posts: 8,918 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I went over to Blind Chicken Racing and looked up CV Joints 101. The 914 CV is a slightly modified Type 1 joint. Type 1 shows to have 12 degrees of articulation. Going to update to 911SC rear stubs and hubs requiring 100mm CV joints. Type 4, Thing 181, 924/944 are all 100mm with 22 degrees of travel. VW Bus and Vanagan are 100mm too but with 17 degrees of travel.
Bus CV joints are about 1/2 the price of 924/944 with 5 degrees more travel than the stock 914. Any reason they would not be more than heavy duty enough for the job? |
Mark Henry |
Dec 3 2015, 07:39 PM
I'll look it up but bus CV's are way bigger than T1/914CV's.
Bigger OD and bigger axle shaft. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:59 AM |
