> Rebuilt 914 1.8 L-Jet Throttle Body
pete000
post Dec 6 2015, 01:23 AM
From my 1974 1.8
Just got my TB back from a total rebuild. Came out really nice. Done by a machinist on the Samba user name whip618 does really nice work.
Machined with bearings and seals, new Pivot shaft, new Butterfly, over bored, rebuilt TPS, All fresh cad plating, machined mounting surfaces. Pressure tested. I just put it in today, but have not had time to try it out. (IMG:style_emoticons/default/aktion035.gif)
Also a new seal by 914 Rubber.
Will post follow up.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
pete000
post Dec 6 2015, 12:04 PM
I had it rebuilt because of wear on the butterfly and leaking shaft pivots.
Very happy with the results of the rebuild.
pete000   Rebuilt 914 1.8 L-Jet Throttle Body   Dec 6 2015, 01:23 AM
914Sixer   Quality work !!   Dec 6 2015, 07:21 AM
orthobiz   Did you have this done to address a particular pro...   Dec 6 2015, 08:52 AM
pete000   I had it rebuilt because of wear on the butterfly ...   Dec 6 2015, 12:04 PM
orthobiz   I had it rebuilt because of wear on the butterfly...   Dec 6 2015, 01:48 PM
porsche913b_sp   wow thats nice, what was the ball park cost if you...   Dec 6 2015, 12:48 PM
396   Very nice!   Dec 6 2015, 01:22 PM
echocanyons   Looks great! Do you know if they replaced or ...   Dec 6 2015, 01:39 PM
Mueller   Looks nice, I have a 2.0 TB I need to refurbish an...   Dec 6 2015, 02:37 PM
jim_hoyland   Really nice. looks better than new... :) Would yo...   Dec 6 2015, 03:00 PM
nihil44   I would also be interested. My main issue is that...   Dec 7 2015, 03:40 AM
whitetwinturbo   Parts Porn :miles:   Dec 7 2015, 10:50 AM
pete000   Not sure if the spring is replaced. He does lots o...   Dec 7 2015, 11:52 AM
pilothyer   Not sure if the spring is replaced. He does lots ...   Dec 7 2015, 12:08 PM
396   Is it possible for someone to post Phil contact in...   Dec 7 2015, 01:02 PM
nihil44   Just got my tb back from Phil. It drives so smoot...   Feb 25 2016, 08:21 PM
396   Just got my tb back from Phil. It drives so smoo...   Feb 26 2016, 11:23 AM
pete000   My car runs so much better after the rebuild. It j...   Feb 25 2016, 11:48 PM
Bartlett 914   The position sensor looks new. Did he replace it?   Feb 26 2016, 11:33 AM
nihil44   Don't know. My guess it has just had a bit a c...   Feb 26 2016, 01:16 PM
- Lo-Fi Version Time is now: 24th November 2024 - 01:26 PM
