porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Purchased one of these small amps for eventual use with my Blaupunkt Frankfurt stereo but it appears this isn't to be (IMG:style_emoticons/default/WTF.gif) .
The instructions state and I quote "it is not recommended that this unit shares speakers with the radio,this unit is more powerful than most radio's and voltage will feedback into the original radio and burn it out''........bloody marvelous not. Anyone sorted this issue or do I just run it thru the din amp connection on the rear of which I have 2 ,one is a six pin and the other a seven from memory. My understanding is that the bridging caps into the two rear din female plugs are to enable the sound from the built-in amp,when these are removed (one or the other)the headunit then receives amplification from and external source......is this correct. Can add a pic of these plugs if required,thanks in advance. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Run it in line like a normal amp. The way I read what you wrote from the instructions is not to run it in parallel to a radio. IE speakers with two feeds. If you run this in line power should not go back to the stereo.
porschetub |
Run it in line like a normal amp. The way I read what you wrote from the instructions is not to run it in parallel to a radio. IE speakers with two feeds. If you run this in line power should not go back to the stereo. Sorry to sound a dumb-ass but I presumed if I ran it with a din plug into the headunit it would be ok?. By the way thanks for the replacement light switch works a treat. |
Lo-Fi Version | Time is now: 27th June 2024 - 06:16 PM |
