porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Purchased one of these small amps for eventual use with my Blaupunkt Frankfurt stereo but it appears this isn't to be (IMG:style_emoticons/default/WTF.gif) .
The instructions state and I quote "it is not recommended that this unit shares speakers with the radio,this unit is more powerful than most radio's and voltage will feedback into the original radio and burn it out''........bloody marvelous not. Anyone sorted this issue or do I just run it thru the din amp connection on the rear of which I have 2 ,one is a six pin and the other a seven from memory. My understanding is that the bridging caps into the two rear din female plugs are to enable the sound from the built-in amp,when these are removed (one or the other)the headunit then receives amplification from and external source......is this correct. Can add a pic of these plugs if required,thanks in advance. |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,335 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
It converts "Hi Output" or Speaker Level Audio to Line Level which is typically used before an amp. If speaker level was introduced to an amp it would probably damage/overdrive it. We used to do that intentionally in the 60's for a cool guitar or organ sound. I used a Bogen PA amp in front of a Fender amp. |
Jeffs9146 |
It converts "Hi Output" or Speaker Level Audio to Line Level which is typically used before an amp. If speaker level was introduced to an amp it would probably damage/overdrive it. We used to do that intentionally in the 60's for a cool guitar or organ sound. I used a Bogen PA amp in front of a Fender amp. (IMG:style_emoticons/default/agree.gif) You can then add a a/b line switch into the amp and run two different devices into the amp. |
Kansas 914 |
(IMG:style_emoticons/default/agree.gif) You can then add a a/b line switch into the amp and run two different devices into the amp. Look at the price for the unit at New Egg: ![]() I think we disconnected the output transformer from the Bogen now that I think about it.... |
Lo-Fi Version | Time is now: 27th June 2024 - 06:14 PM |
