> Stock CV Joint Angle of Degree Articulation, Is More Better for a Stock Axle?
914Sixer
post Dec 1 2015, 08:51 PM
I went over to Blind Chicken Racing and looked up CV Joints 101. The 914 CV is a slightly modified Type 1 joint. Type 1 shows to have 12 degrees of articulation. Going to update to 911SC rear stubs and hubs requiring 100mm CV joints. Type 4, Thing 181, 924/944 are all 100mm with 22 degrees of travel. VW Bus and Vanagan are 100mm too but with 17 degrees of travel.
Bus CV joints are about 1/2 the price of 924/944 with 5 degrees more travel than the stock 914. Any reason they would not be more than heavy duty enough for the job?
914Sixer
post Dec 8 2015, 10:07 PM
914 stock axle shafts are 20 1/4". If I remember correctly the Bus ones are shorter. 944's are short about 1/4" if you use one side of the auto trans axle. Need to re-read the axle thread.
914Sixer   Stock CV Joint Angle of Degree Articulation   Dec 1 2015, 08:51 PM
DBCooper   Yes, stronger and cheaper. I don't know but s...   Dec 1 2015, 09:01 PM
Mike Bellis   You only need as much articulation as you have. To...   Dec 1 2015, 09:41 PM
Eric_Shea   I always go for the stock angle (or more). When...   Dec 2 2015, 12:01 PM
ThePaintedMan   I really liked SirAndy's how-to on using the 9...   Dec 2 2015, 05:38 PM
914Sixer   The stock 914 axle MAY NOT need machining accordin...   Dec 2 2015, 06:13 PM
DBCooper   Maybe DB will chime in and let us know IF he had ...   Dec 3 2015, 10:21 PM
Dave_Darling   I think the spline count is the same between the T...   Dec 3 2015, 10:29 AM
914Sixer   Bus Lobro CV joints on the way. We will see how t...   Dec 3 2015, 07:30 PM
Mark Henry   I'll look it up but bus CV's are way bigge...   Dec 3 2015, 07:39 PM
Mark Henry   You might be right, but here's some light read...   Dec 3 2015, 07:57 PM
914Sixer   Mark, I will be using 100mm 911 SC hubs, stubs and...   Dec 3 2015, 08:35 PM
914Sixer   OK, the 100mm bus CV's came in today. Disasse...   Dec 7 2015, 07:12 PM
McMark   Sweet! Axle components are next on my shoppin...   Dec 8 2015, 07:03 AM
ThePaintedMan   Awesome! Thank you!   Dec 8 2015, 07:15 AM
gryphon68   How about a 70 degree bootless CV? https://www.in...   Dec 8 2015, 01:41 PM
Dave_Darling   How about a 70 degree bootless CV? https://www.i...   Dec 9 2015, 06:22 PM
914Sixer   Probably end up in off the road and military appli...   Dec 8 2015, 05:48 PM
bretth   I have a set of both Bus and 944 CVs with axles an...   Dec 8 2015, 07:19 PM
914Sixer   914 stock axle shafts are 20 1/4". If I remem...   Dec 8 2015, 10:07 PM
Mueller   Wondering if this is false economy if not using go...   Dec 8 2015, 10:13 PM
DBCooper   Wondering if this is false economy if not using g...   Dec 9 2015, 09:10 AM
Eric_Shea   Wondering if this is false economy if not using ...   Dec 10 2015, 12:34 PM
914Sixer   Yep, that is why Eric Shea says he ONLY sells GKN...   Dec 9 2015, 06:47 AM
Racer Chris   I didn't have any CV failures until my supplie...   Dec 9 2015, 08:17 AM
Mike Bellis   Ultimate 108mm CV http://www.rcvperformance.com/pr...   Dec 10 2015, 06:37 PM
Mueller   Ultimate 108mm CV http://www.rcvperformance.com/p...   Dec 10 2015, 08:42 PM
Mike Bellis   [quote name='Mike Bellis' post='2275771' date='De...   Dec 10 2015, 08:52 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 02:32 PM
