> Seat removal, How to
74ravenna
post Nov 15 2015, 12:07 PM
I hate to ask because it should be pretty straight forward and I've searched the site for an explanation but couldn't find one.
So, what is the process for seat removal? The bolts at the rear of the track are easy enough to access but what about the forward bolts?
Or does the seat slide out of the tracks somehow?
I just need to access the wiring and do a little cleaning (surface rust removal) of the floor.
Thanks in advance.
Dave_Darling
post Dec 13 2015, 01:54 PM
914 Idiot
Yes. Splice the thick yellow/red wires together, and cover the splice with shrink tubing, to keep water and dirt out. Unless your 914 has no leaks. (IMG:style_emoticons/default/wink.gif)
--DD
74ravenna
post Dec 13 2015, 02:06 PM
QUOTE(Dave_Darling @ Dec 13 2015, 02:54 PM) *
--DD
Ok, will do!
Leaks? Its probably not "if" it leaks but how many leaks it'll have once its on the road.
It hasn't been started in 32 years. It just sat it the POs cellar for that whole time so lots of dry rubber.
Thanks once again for the help.
Steve
74ravenna   Seat removal   Nov 15 2015, 12:07 PM
mepstein   The seat slides off the track. I slide my finger u...   Nov 15 2015, 12:16 PM
Montreal914   Two ways: What you described; 2 screws on each si...   Nov 15 2015, 12:21 PM
74ravenna   Yup, came right out. Now, there were/are disconne...   Nov 15 2015, 01:31 PM
Dave_Darling   Sounds like you have a 74? If so, those are for t...   Nov 15 2015, 03:24 PM
74ravenna   Sounds like you have a 74? If so, those are for ...   Dec 13 2015, 10:55 AM
396   [quote name='Dave_Darling' post='2265445' date='N...   Dec 13 2015, 11:01 AM
74ravenna   I do have a 74! I will take your advice and d...   Nov 16 2015, 03:38 AM
RobW   Not a bad idea to clean the rails and add some lub...   Nov 16 2015, 06:40 AM
74ravenna   I am definitely cleaning and lubing the rails. The...   Nov 16 2015, 08:29 AM
orthobiz   My take on it in an old thread with lots of (excru...   Nov 16 2015, 09:26 PM
Dave_Darling   Yes. Splice the thick yellow/red wires together, ...   Dec 13 2015, 01:54 PM
74ravenna   Yes. Splice the thick yellow/red wires together,...   Dec 13 2015, 02:06 PM
jbyron   Ok, zombie thread time. I just pulled my driver se...   Aug 10 2024, 11:42 AM
Cairo94507   The seat slider adjuster should be adjacent to the...   Aug 10 2024, 04:10 PM
jbyron   The seat slider adjuster should be adjacent to th...   Aug 10 2024, 08:11 PM
doug_b_928   The silver brackets (one of which has the black ha...   Aug 10 2024, 08:28 PM
jbyron   The silver brackets (one of which has the black h...   Aug 12 2024, 08:11 AM
- Lo-Fi Version Time is now: 6th January 2025 - 05:30 PM
